The proposed development would be used in-house and would not be made
available outside of the company, so I have always assumed that this type of
development was not eligible for ADN membership. I am sure if required I
would get the funding if by some chance this type of coding was expectable?
Laurence Skoropinski
Amdega Ltd
"Stephen Preston" wrote in message
news:D41AE1CA6DC6B9602637401439DA5EC7@in.WebX.maYIadrTaRb...
> Your assumption is correct. And you can use anything we ship with the
> ObjectARX SDK to develop your applications.
> However, since you're developing a 'building' have you considered using
> Architectural Desktop - the ADT-specific entities (walls, doors, windows,
> etc) may provide what you need.
> And have you considered joining ADN - www.autodesk.com/adn. If you join at
> the 'professional' level, you'll get free telephone consulting that you
can
> use to ask for design and implementation advice to make sure you're going
in
> the right direction.
> Cheers,
> Stephen Preston
> Developer Technical Services
> Autodesk
> http://adn.autodesk.com
> "Laurence Skoropinski" wrote in
message
> news:6B4F158FB20F12D506985D1343A9320C@in.WebX.maYIadrTaRb...
> > Hello
> > I am fairly new to ObjectARX and have completed a couple of small
projects
> > using it.
> > I am know looking at 3D drawings and I see we can use AcDb3dSolids to
> create
> > and manipulate solid objects, but I also came across the AModeler in the
> > Utils directory.
> > It appears to do much the same as the 3D models only using a face rather
> > than solid graphics interface, hence a smaller file size. So the
questions
> > are, as it is in the Utils directory I assume we can use it. Has anyone
> used
> > it to model 3d stuff, and finally have I made the correct assumption as
> > stated above ?
> > Maybe I should state exactly what I want to do, This is to create 3D
> > drawings of conservatories (glass houses). This is lightly to be a big
> > project, so I do not want to start on the wrong path.
> > Amdega Ltd
