ObjectARX
Valued Contributor
jwscad
Message 1 of 4 (240 Views)
Adding custom property to Quick Property
240 Views, 3 Replies
11-23-2012 12:41 PM
Posted in AutoCAD 2011. Should go here I think.
I use Quick Properties in static mode mostly for counting objects and quickly seeing the length of lines and polylines. These lengths are listed in feet and inches. Would it be possible to add an additional length item to the quick properties menu which shows the inches/decimal length? Would be awesome as I wouldn't then have to do the math to convert to inches. Thanks
I found this:http://through-the-interface.typepad.com/through_the_interface/2008/11/adding-custom-p.html
which is a start but considering that I have no idea how to do this are there any resources or guides to getting started building something like this?
John
AutoCAD 2011
win 7
ADN Support Specialist
Balaji_Ram
Message 2 of 4 (208 Views)
Re: Adding custom property to Quick Property
12-03-2012 07:30 AM in reply to: jwscad
Hello John,
Have you looked at the sample in the ObjectARX 2009 that demonstrates Quick Properties ?
If not, you can find it under :
ObjectARX 2009\samples\com\QuickProperties
Balaji
Developer Technical Services
Autodesk Developer Network
Valued Contributor
jwscad
Message 3 of 4 (199 Views)
12-03-2012 10:52 AM in reply to: Balaji_Ram
I am running AutoCAD 2011. I also dont have any experience using ObjectARX. I downloaded and installed ObjectARX 2011 but that particular sample does not exist. Thanks
Moderator
Alexander.Rivilis
Message 4 of 4 (182 Views)
12-04-2012 05:10 AM in reply to: jwscad
You can download ObjectARX SDK 2009 and look at this sample.
Old versions of ObjectARX SDK.
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
