Show only
Search instead for
chris wrote:
> hi everybody,
> question:
> i use loadlibrary to load a dll to autocad.
> ist it posible to register an dll or arx from dllmain to autocad?
> how do i implement the acrxEntryPoint if the funktion
> acrxEntryPoint() is not called?
> regards
> chris
Use acrxLoadModule() instead of LoadLibrary() and your entry point
function will be called.
chris wrote:
> hmm,
> is there no other oportunity to get this funktion called?
> how does autocad itself call this funktion?
> why does autocad use acrxEntryPoint and not dllmain?
> regards
> chris
AutoCAD does call DllMain(), I'm sure acrxLoadModule() calls
LoadLibrary() to map the dll/arx into memory. Then AutoCAD calls your
acrxEntryPoint() function. What are you trying to do and what doesn't
appear to be working?
