ObjectARX
ObjectARX
oliver253m
Message 1 of 2 (223 Views)
AcPublish.arx needs to be loaded before acplPublishExecute
223 Views, 1 Replies
10-01-2012 02:30 PM
Greetings,
I ran into a small issue and didn't find any mention of it in the documentation or the forum, so I hope this helps someone.
If you call the acplPublishExecute() function without having used the PUBLISH command, publishing will fail with an empty error in the log.
It appears that the PUBLISH command will load the AcPublish.arx module as needed, but acplPublishExecute() will not, so make sure to load it yourself.
ADN Support Specialist
philippe.leefsma
Message 2 of 2 (119 Views)
Re: AcPublish.arx needs to be loaded before acplPublishExecute
08-14-2013 12:22 AM in reply to: oliver253m
Thanks for the tip. You can also use acedArxLoad to load AcPublish.arx programmatically prior to run your publish code.
Philippe.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
