ObjectARX
AcGeVector3d question?
2 REPLIES 2
238 Views, 2 Replies
What is the easiest way to tell if two lines are going in the same direction.
Eg: P1 & P2
P1 startPoint = 0,0,0 end point = 1,0,0
P2 startPoint = -1,0,0 end point = 0,0,0
They are actually going away from each other. How can I tell using Vectors?
Any help?
Mike Bujak
2 REPLIES 2
Here is a test code, it might help:
ads_point pt1, pt2, pt3, pt4;
acedGetPoint(NULL, "\nLine from: ", pt1);
acedGetPoint(pt1, "\nLine to: ", pt2);
acedGetPoint(NULL, "\nLine from: ", pt2);
acedGetPoint(pt2, "\nLine to: ", pt3);
AcGePoint3d ptA( pt1, pt1, pt1 );
AcGePoint3d ptB( pt2, pt2, pt2 );
AcGePoint3d ptC( pt3, pt3, pt3 );
AcGePoint3d ptD( pt4, pt4, pt4 );
AcGeLine3d line1(ptA,ptB) , line2(ptC,ptD);
AcGeVector3d v1 = line1.direction();
AcGeVector3d v2 = line2.direction();
if ( v1.angleTo(v2) != v2.angleTo(v1) ){
acutPrintf("\nSame direction");
else {
acutPrintf("\nNot the same direction");
http://www.geometricad.com
wrote in message news:5097904@discussion.autodesk.com...
direction.
Eg: P1 & P2
Any help?
Mike Bujak
Mike_B schrieb:
Hi Mike,
> Eg: P1 & P2
You can use AcGeVector3d::isCodirectionalTo()
AcGeVector3d v1 = endpoint1-startpoint1;
AcGeVector3d v2 = endpoint2-startpoint2;
if (v1.isCodirectionalTo(v2))
HTH
Arnold
”Boost
