ObjectARX
AcGePoint3d sorting
3 REPLIES 3
769 Views, 3 Replies
AcGePoint3d sorting
Probably more of a C++ question than ARX, and I'm sorry ahead of time, but can anyone tell me what is going wrong here? The code below will compile and run when I pass in an AcGePoint3dArray of several points, but the array is unchanged after it runs...
int pointSortByX(const void *p1, const void *p2){
	return ((AcGePoint3d*)p1)->x - ((AcGePoint3d*)p2)->x;}
int pointSortByY(const void *p1, const void *p2){
	return ((AcGePoint3d*)p1)->y - ((AcGePoint3d*)p2)->y;}
void sortPoints(AcGePoint3dArray allIntersPts)
	/*the first two elements are the start and endpoints. Use them to determine
	if the array should be sorted by x or y values. */
	double distInX = abs(allIntersPts.at(0).x - allIntersPts.at(1).x);
	double distInY = abs(allIntersPts.at(0).y - allIntersPts.at(1).y);
	//if the line is more vertical, then sort by the y-coords
	if(distInY > distInX)
		std::qsort(allIntersPts.asArrayPtr(), allIntersPts.length(), sizeof(AcGePoint3d), pointSortByY);
	//else the line is more horizontal, then sort by the x-coords
	else
		std::qsort(allIntersPts.asArrayPtr(), allIntersPts.length(), sizeof(AcGePoint3d), pointSortByX);
	return;
AcGePoint3dArray allIntersPts;
/*code to append some points*/
acutPrintf(_T("\nBefore sort:"));
		for(int i = 0; i < allIntersPts.logicalLength(); i++)
			acutPrintf(_T("\n%d: %.3f, %.3f"), i, allIntersPts.at(i).x, allIntersPts.at(i).y);
sortPoints(allIntersPts);
acutPrintf(_T("\nAfter sort:"));
 TIA,
Ralph Gaston
3 REPLIES 3
artc2
You need to pass the array by reference so that you are operating on the original array not a copy.
owenwengerd
It looks like you intended to pass  the argument to sortPoints() by reference instead of by value.
Owen Wengerd
ManuSoft
That appears to have fixed it. Thanks to both of you. I thought I was passing in the address just because it was an array. Pretty embarrassing, but no telling how much time it saved me. Thanks again!
”Boost
