acedSSLength gives invalid result
Hi, I don't know how to properly title this post. I'll try to describe it.
1. Open Autocad
2. Draw 5 lines (let's say paralell lines)
3. Select them all with area (mouse move)
4. Now press shift and holding shift move your mouse from right lower corner into left upper - selecting all the lines.
If you have done all operations well, every line should be now unselected.
Now, when my Autocad loads my application, there something different happens. When I select all the lines, I get pickFirstModified and everything is ok.
But when I'm trying to unselect them all (like I have written earlier), pickFirstModified is called, but then:
resbuf * p = NULL;
int result = acedSSGetFirst(NULL, &p); //it gives me selection set
if((p != NULL) && (result == RTNORM))
		m_name[0] = p->resval.rlname[0];
		m_name[1] = p->resval.rlname[1];
		acutRelRb(p);
//now, I check the length
long len;
int result = acedSSLength(m_name, &len);
This length gives me 4. What's more, the 4 lines on the drawing are actually still selected. Only one is unselected. Does anyone of you knows the reason why?
nick83
can't understand, what makes you think that you unselect objects?
nevermind)))
for selecting:
ads_name _preselect, en1;
AcDbObjectIdArray wantedObjectsToBeSelected;// fill it with ids acedSSAdd(0,0,_preselect);
for (int i = 0; i < wantedObjectsToBeSelected.length(); i++)
{ acdbGetAdsName(en1,wantedObjectsToBeSelected.at(i)); acedSSAdd(en1,_preselect,_preselect);
} acedSSSetFirst(_preselect, NULL);
acedSSFree(_preselect);
to clear selection:
acedSSSetFirst(NULL, NULL);
and, can't remember exactly, but it seems, that  flags ACRX_CMD_USEPICKSET | ACRX_CMD_REDRAW have to be added to your command description
PS: about your code... it must crush autocad )))
if you want to get ids of preselect, you have to use something like this:
AcDbObjectIdArray preSelect(bool clearSelection = false)
	AcApDocument * pDoc = acDocManager->mdiActiveDocument();
	acDocManager->lockDocument(pDoc);
	AcDbObjectId eId;
	AcDbObjectIdArray entArr; entArr.removeAll();
	ads_name ent, one_ent;
	long len = 0L;
	struct resbuf *grip_set = NULL, *ents = NULL;
	int res = acedSSGetFirst(&grip_set, &ents);
	if (res == RTNORM)
		if (ents)
			if (ents ->restype == RTPICKS)
				acedSSLength(ents->resval.rlname, &len);
				for (long a = 0; a < len; a++)
					if (ads_ssname(ents->resval.rlname,a,one_ent)!=RTNORM)continue;
					if(acdbGetObjectId(eId, one_ent)!= Acad::eOk)continue;
					entArr.append(eId);
				acedSSFree(ents->resval.rlname);
			acutRelRb(ents);
		if (grip_set)
			if (grip_set->restype == RTPICKS) acedSSFree(grip_set->resval.rlname);
			acutRelRb(grip_set);
	if (clearSelection)
	acDocManager->unlockDocument(pDoc);
	return entArr;
I don't think you understand my problem. Maybe because title of the post may not be the proper one.
One more time:
When I have 5 lines selected and want to unselect them - on the drawing - I can press shift and while holding shift drag mouse over the entities I want to unselect. After this operation, when my application is loaded only one line is unselected. Not all of them.
tbrammer
You say that your application unintentionally changes the behavior of AutoCAD's Shift-select. And you want to find out why. Right?
Do you use functions that modify the pickfirst set?
Maybe even in reactors?
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
tbrammer
You posted this recently. Do you use an AcEdSSGetFilter?
Exactly.
Actually I do. I mean I have this reactor connected to the document, but all the methods are empty.
It has occured that it works fine in Autocad 2014. Code is the same.
