ObjectARX
acedEntSel doen't return RTKWORD
6 REPLIES 6
johnteng00
987 Views, 6 Replies
Hi guys,
I need your help. I use the following two function to set up the key words in the new command in my plugin:
acedInitGet(0, ACRX_T("noBendinglines Kfactor"));
acedEntSel("\n Pick a sheetmetal solid[noBendinglines/Kfactor]", ent_name, asDblArray(pickPnt)))
From the comand line, I can see the listed key two words:"noBendlinglines" and "Kfactor". But when I double click any key word, my program doesn't catch the return parameter value "RTKWORD". Basically there is no return from the function "acedEntSel". Could anyone please  help me? I am stuck there.
Regards
John
6 REPLIES 6
owenwengerd
in reply to: johnteng00
Double clicking on a keyword in a command prompt does not enter it. You have to type it (or select it from a context menu).
Owen Wengerd
ManuSoft
johnteng00
in reply to: owenwengerd
thank you for your reply. but even I type it in the context menu, it still doesn't work. It seems to me that the "acedEntSel" never returns even I type a key word.
owenwengerd
Perhaps someone can help if you post code that demonstrates the problem
Owen Wengerd
ManuSoft
johnteng00
Hi guys,
below is the code snippet. Please note the function acedEntSel and acedInitGet I have in the codes. I appreciate if anyone can pass me the code snippet to do the same thing.
I am stuck here and thank you very much for your help.
Regards
John
bool show_bending_line_flag = false;
Acad::ErrorStatus acadReturnValue = Acad::eOk;
int errStat = RTERROR;
ads_name sset;
AcGePoint3d pickPnt;
struct resbuf org_osnap;
acedGetVar(ACRX_T(
"OSMODE"), &org_osnap);
struct resbuf new_osnap = org_osnap;
new_osnap.resval.rint = 0;
int dbg = 2;
acedSetVar(ACRX_T("OSMODE"), &new_osnap);
double k_factor = get_k_factor();
ostringstream ostr;
ostr << k_factor;
AcString kstr(ostr.str().c_str());
AcString tmp_prompt("\n Pick a sheetmetal solid[noBendinglines/Kfactor]");
AcString propmt = tmp_prompt;
//+ kstr + cend;
//acedInitGet(0, ACRX_T("K-Factor"));
int ic = 0;
while ((errStat != RTNORM) && (errStat != RTCAN) && (errStat != RTREJ) && (errStat != RTNONE))
        ads_name ent_name;
    switch(subType)
         case AcDb::kNullSubentType:
         for (;;)
              switch (acedEntSel(propmt, ent_name, asDblArray(pickPnt)))
                  case RTNORM:
                      break; // get the solid name in the codes below
                  case RTKWORD:
                  // read the key wordname and check whether user want to show bending line
                                             ACHAR kw[20];
                     if (_tcscmp(kw, _T("noBendinglines")) == 0)
                                                     ostr << k_factor;
                         if( ic %2 == 0 )
                                                              AcString tmp_prompt0("\n Pick a sheetmetal solid[Bendinglines/Kfactor]<Kfactor=");
                                                              AcString cend(">");
                                                              propmt = tmp_prompt + kstr + cend;
                                                              show_bending_line_flag = true;
                         else
                                                              AcString tmp_prompt0("\n Pick a sheetmetal solid[noBendinglines/Kfactor]<Kfactor=");
                                                              AcString cend(">");
                                                              show_bending_line_flag =false;
                                                     ic++;
                     if (_tcscmp(kw, _T("Kfactor")) == 0)
                                                     std::string str("\nEnter K-Factor<");
                                                     ostringstream ostr;
                                                     ostr << k_factor;
                         double backup_k_factor = k_factor;
                                                     string txt = str + ostr.str() +">:";
                                                     AcString astr(txt.c_str());
                         int err = acedGetReal(astr.kTCharPtr(), &k_factor);
                                                     ostr << k_factor;
                                                    AcString tmp_prompt("\n Pick a sheetmetal solid[noBendinglines/Kfactor]<Kfactor=");
                                                    AcString cend(">");
                    default:
                    break;
               break;
//errStat = acedEntSel(ACRX_T("\n Pick a sheetmetal solid[bendinglines/kfactor]\n"), ent_name, asDblArray(pickPnt));
//if (errStat == RTKWORD)
// dbg = 2;
          break;
          default:
                         acutPrintf(ACRX_T("\n getPath: unsupported subentity type: %d\n"), subType);
       return Acad::eInvalidInput;
if (errStat == RTERROR)
struct resbuf buf_errno;
acedGetVar(ACRX_T(
"ERRNO"), &buf_errno);
if (buf_errno.resval.rint == OL_ENTSELNULL) errStat = RTNONE;
loic.jourdan
I see two points that may be fixed:
 - First `acedInitGet(...);` has to be called right before each call to `acedEntSel`, in you case, right before your switch. Otherwise, the keywords won't be available for next `acedEntSelcalls.
 - Second: you never get the value of the keyword, you declare `ACHAR kw[20];` and compare it right after without getting its actual value. You have to call `acedGetInput()` to fill in your kw variable with the actual input keyword.
Except that, I've ran it approximatively successfully (at least, I've got the code in `switch/case RTKWORD` executed correctly)
I hope this helps
20-20 CAD / 20-20 Technologies
johnteng00
in reply to: loic.jourdan
Hi loic.jourdan,
thank you very much. It works now.
John
”Boost
