ObjectARX
AcDbObjectId ....
4 REPLIES 4
371 Views, 4 Replies
AcDbObjectId ....
In some machine AcDbObjectId.asOldId() return an integer < 0 ? has someone
an explanation?
Thank's in advance Alessandro
4 REPLIES 4
That would happen if the value's highest bit is set. The actual value being
returned is a memory address which is really an unsigned long (in 32-bit
Acad), but asOldId() returns a signed value.
"Alessandro" wrote in message
news:6134870@discussion.autodesk.com...
an explanation?
Thank's for explaining why if i return an unsigned long as long, the number
can be negative, but the question is still different; why only in some
machine the id is stored so big to set the highest bit?
"Art Cooney" ha scritto nel messaggio
news:6134918@discussion.autodesk.com...
an explanation?
Are they all 32 bit versions of AutoCAD on 32 bit Windows?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000 through 2009
http://www.acadxtabs.com
Introducing AcadXTabs 2010:
http://www.caddzone.com/acadxtabs/AcadXTabs2010.htm
news:6135000@discussion.autodesk.com...
an explanation?
yes, AutoCAD 32bit, Windows XP sp2 32 bit; the only different from other
pc's is the nvidia sata, but i don't thinks is this the problem....
"Tony Tanzillo" ha scritto nel messaggio
news:6135005@discussion.autodesk.com...
an explanation?
”Boost
