ObjectARX
AcDbHatch in 3d
23 REPLIES 23
Message 1 of 24
PEPANOVAK
1888 Views, 23 Replies
AcDbHatch in 3d
I can in 2d, but in 3d not working (after setting ECS by 3dface)...
Any idea?
Thanks.
Pepa
23 REPLIES 23
Message 21 of 24
maisoui
in reply to: owenwengerd
As a suggestion: another approach is to implement a custom entity and use the mesh function in your world or viewport draw where you can manage faces and edges
pMode->geometry().mesh(...)
Certainly more efficient than a lot of AcDbHatch.
Jonathan
Message 22 of 24
PEPANOVAK
in reply to: maisoui
I have a TIN created just as custom entity ( pW->geometry().shell(numVerts, pVerts, faceListSize, pFaceList); ), but there (AcGiFaceData) can not be used gradient color?
Message 23 of 24
maisoui
in reply to: PEPANOVAK
No, I guess it's not possible, but you can define materials on each face. If you want a gradient color on all your "solid", I guess you need to change the color on each face depending on its "level".
Jonathan
Message 24 of 24
PEPANOVAK
Here is the code for 3D gradient hatches. This works...
                    // elev is difference min Z and max Z TIN
                    double base = 1.0 / elev;
                    for (Adesk::UInt32 i=0; i < numFaces; i++) {
                        trig=sezT[i];
                        A=trig.pointA;
                        B=trig.pointB;
                        C=trig.pointC;
                        AcGePlane planeTarget(A, B, C);
                        AcGeVector3d vecNormal = planeTarget.normal();
                         // return Point with min/max  Z coords
                        minB=minDoublePoint(A,B,C);
                        maxB=maxDoublePoint(A,B,C);
                        uhel=atan2(vecNormal.y,vecNormal.x);
                        if (fabs(minB.z-maxB.z) < EPSILON) {
                            uhel=0.0001;
                        geoCOLOR iC1,iC2;
                        float value1, value2;
                        // minZ and maxZ are min/max Z coords TIN
                        value1 = 1 - (base * (maxZ - minB.z));
                        value2 = 1 - (base * (maxZ - maxB.z));
                        // interpolating 2 color
                        iC1=interpolate(c1, c2, value1);
                        iC2=interpolate(c1, c2, value2);
                        // wrong, only positives value
                        //double dElevation = AcGePoint3d::kOrigin.distanceTo(AcGePoint3d::kOrigin.orthoProject(planeTarget));
                        double vzd;
                        // my function for distance
                        distancePointPlane(A,B,C,AcGePoint3d::kOrigin,vzd);
                        AcDbHatch* pHatch = new AcDbHatch();
                        pHatch->setDatabaseDefaults();
                        Acad::ErrorStatus es = pHatch->setElevation(vzd); assert(es==Acad::eOk);
                        es = pHatch->setNormal(vecNormal); assert(es==Acad::eOk);
                        AcGePoint2dArray rpt2Loop;
                        AcGeMatrix3d mxECS;
                        pHatch->getEcs(mxECS);
                        mxECS.invert();
                        AcGePoint2d pt2A = A.transformBy(mxECS).convert2d(AcGePlane::kXYPlane);
                        AcGePoint2d pt2B = B.transformBy(mxECS).convert2d(AcGePlane::kXYPlane);
                        AcGePoint2d pt2C = C.transformBy(mxECS).convert2d(AcGePlane::kXYPlane);
                        rpt2Loop.append(pt2A);
                        rpt2Loop.append(pt2B);
                        rpt2Loop.append(pt2C);
                        es = pHatch->appendLoop(AcDbHatch::kExternal, rpt2Loop, AcGeDoubleArray() ); assert(es==Acad::eOk);
                        pHatch->setLayer(hladinaPom);
                        AcCmColor colors[2];
                        colors[0].setRGB(iC1.red,iC1.green,iC1.blue);
                        colors[1].setRGB(iC2.red,iC2.green,iC2.blue);
                        float ff[2] = {0.0, 1.0};
                        pHatch->setHatchObjectType(AcDbHatch::kGradientObject);
                        pHatch->setGradient(AcDbHatch::kPreDefinedGradient,_T("LINEAR"));
                        pHatch->setGradientColors(2,colors,ff);
                        pHatch->setGradientOneColorMode(Adesk::kFalse);
                        // calculation angle
                        double rotAngle = uhel + (PI/2.0-vecNormal.angleOnPlane(AcGePlane::kXYPlane));
                        pHatch->setGradientAngle((rotAngle));
                        es = pHatch->evaluateHatch(); assert(es==Acad::eOk);
                        addToModelSpace(eId,pHatch);
Pepa
”Boost
