ObjectARX
ObjectARX
Valued Contributor
mbujak
Message 1 of 3 (152 Views)
AcDbGripData GetGripPoints() confusion......
152 Views, 2 Replies
02-07-2012 08:46 AM
It states in the documentation:
"The caller is responsible for freeing the AcDbGripData objects whose pointers are in the grips array."
I am fine with this, but, to do this the array of grip data objects must be stored or cached somewhere in order to be cleaned up. How do you do this when the subGetGripPoints() function is 'const'? Surely a member variable on the custom entity won't suffice.
Any suggestions?
Mike
Distinguished Mentor
owenwengerd
Message 2 of 3 (150 Views)
Re: AcDbGripData GetGripPoints() confusion......
02-07-2012 09:04 AM in reply to: mbujak
If the caller is responsible for the AcDbGripData objects, you can't safely cache pointers to their memory (because the caller will delete them, leaving you with pointers to freed memory).
Owen Wengerd
ManuSoft
Owen Wengerd
ManuSoft
Valued Contributor
mbujak
Message 3 of 3 (147 Views)
02-07-2012 09:19 AM in reply to: mbujak
Ok, so, in the case of subGetGripPoints(...) the caller would be the Autocad framework, so I don't need to worry about the AcDbGripData object pointers themselves... Just any appData structures that I may pass into them.
Mike
