ObjectARX
AcDbDatabaseReactor
5 REPLIES 5
varadan01
745 Views, 5 Replies
AcDbDatabaseReactor
Please provide me a sample code with EntryPoint to invoke and implement AcDbDatabaseReactor functions.
With Regards,
GVaradarajan
5 REPLIES 5
ObjectARX SDK:
1) samples\editor\mfcsamps\modeless
2) samples\reactors\dbreact_dg
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
while trying to implement DbReact.sln from ObjectARX SDK in a new ObjectARXSolution in visual studio 2008,the following errors occuring:
Error    1    error LNK2005: "class AsdkAppDocGlobals * gpAsdkAppDocGlobals" (?gpAsdkAppDocGlobals@@3PAVAsdkAppDocGlobals@@A) already defined in acrxEntryPoint.obj    DbReact.obj    React
Error    2    fatal error LNK1169: one or more multiply defined symbols found    E:\vani_august\React\Win32\Debug\AsdkReact.arx    React
I herewith attached the files in that solution as a text file for your reference. please provide any solutions to fix the above errors.
With Regards,
GVaradarajan
You instantiate gpAsdkAppDocGlobals in DbReact.h which included twice: from DbReact.cpp and acrxEntryPoint.cpp
Expert Elite Member
After fixing the above issue, my code is as in the text file attached below; and this code is successfully compiled but when try apploading its ".arx" file to AutoCAD 2012,its throwing a below error in command prompt: Command: appload 捡硲湅牴偹楯瑮 not found in asdkreact.arx AcRxDynamicLinker failed to load 'e:\vani\react\win32\debug\asdkreact.arx' C:\Program Files\Autodesk\AutoCAD 2012 - English\acad.exeUnable to load AsdkReact.arx file. Please provide a solution to fix the above issue and to load ".arx' file and debug the code successfully.
With Regards,
GVaradarajan
Comment (or delete) class CReactApp.
Expert Elite Member
”Boost
