"Andy Elmore" <
href="mailto:pioneerww@bellsouth.net">pioneerww@bellsouth.net> wrote in
message
href="news:F338694D5CEBAC99D3998E188E44E0CE@in.WebX.maYIadrTaRb">news:F338694D5CEBAC99D3998E188E4......
Can I get some info on this arx object
AcDb3dSolid. I would like to find out how I could remove it's grips and how
have it drawn in a loction other than 0,0,0 maybe 1220,305,40? just some way
that I can have it in a location that I tell it to progmaticly. I could
not find it in the docs one of its built in functions.
Andy
size=2>
"Stephen Preston" <
href="mailto:discussion.support@autodesk.com">discussion.support@autodesk.com>
wrote in message
href="news:2C932B421745978F9D2093B3E0C810DC@in.WebX.maYIadrTaRb">news:2C932B421745978F9D2093B3E0C......
Hi Andy,
To move it, you'd call the entity's transformBy()
function and pass in a translation matrix.
To remove the grips, you can derive from
AcDb3dSolid and override the grippoints functions in your own
implementation.
Cheers,
Stephen Preston
Developer Technical Services
href="http://adn.autodesk.com">http://adn.autodesk.com
"Andy Elmore" <
in message
href="news:F338694D5CEBAC99D3998E188E44E0CE@in.WebX.maYIadrTaRb">news:F338694D5CEBAC99D3998E188......
Andy
size=2>
"Stephen Preston" <
wrote in message
Hi Andy,
implementation.
Cheers,
Stephen Preston
"Andy Elmore" <
in message
Andy
size=2>
"Lou" <louh62@yahoo.com>
wrote in message
href="news:B3F5F112C6EF487A6287BD06395B1064@in.WebX.maYIadrTaRb">news:B3F5F112C6EF487A6287BD06395......
Stephen,
To derive from AcDb3DSolid and override the grips
would need custom object, right?
Thanks!
-Lou
"Stephen Preston" <
wrote in message
href="news:2C932B421745978F9D2093B3E0C810DC@in.WebX.maYIadrTaRb">news:2C932B421745978F9D2093B3E......
Hi Andy,
transformBy() function and pass in a translation matrix.
implementation.
Cheers,
Stephen Preston
"Andy Elmore" <
wrote in message
href="news:F338694D5CEBAC99D3998E188E44E0CE@in.WebX.maYIadrTaRb">news:F338694D5CEBAC99D3998E1......
how have it drawn in a loction other than 0,0,0 maybe 1220,305,40? just
some way that I can have it in a location that I tell it to
progmaticly. I could not find it in the docs one of its built in
functions.
Andy
size=2>
"Andy Elmore" <
message
href="news:D20B1BF55502CE53D7313277E46F1A6E@in.WebX.maYIadrTaRb">news:D20B1BF55502CE53D7313277E46......
What type of 3dSolid would I need to use to have
a user edited 3d solid (pretty much a mass element with less grips) but has
the chamfering properties as a 3d solid. I did a search on mass elements
in the arx help files but nothing turned up.
Andy
face=Arial size=2>
"Stephen Preston" <
href="mailto:discussion@autodesk.com">discussion@autodesk.com> wrote in
message
href="news:D3C7C7E5B24277D1C73E703E61179811@in.WebX.maYIadrTaRb">news:D3C7C7E5B24277D1C73E703E611......
Hi Andy,
I'm not sure I understand what you're
after.
AcDb3dSolid is a container for an Autodesk Shape
Manager (or ACIS before 2002) solid. AcDb3dSolids all behave the same - its
the contained solid that differs. The methods to create various ASM
shapes are all described in the AcDb3dSolid entry in the helpfiles. In
AutoCAD, pretty much the only programmatic editing you can do is a Boolean
operation. More complex programmatic editing functions are available in MDT.
You should be able to chamfer any AcDb3dSolid
(regardless of its shape) using the UI (modify menu).
size=2>
Cheers,
Stephen Preston
"Andy Elmore" <
in message
href="news:D20B1BF55502CE53D7313277E46F1A6E@in.WebX.maYIadrTaRb">news:D20B1BF55502CE53D7313277E......
have a user edited 3d solid (pretty much a mass element with less grips) but
has the chamfering properties as a 3d solid. I did a search on mass
elements in the arx help files but nothing turned up.
Andy
face=Arial
size=2>
Hi
How to set grip point using createbox methods in acdb3dsolid Class.
