AcArray sort
AcArray sort
AcArray sort
I want to sort some items in a AcArray but it isn't working as expected.
[code]
std::sort(&data.first(), &data.last(), SortFileData);
bool SorFileData(const PlotItem& item1, const PlotItem& item2)
double x1 = min(item1._start.x, item1._end.x);
double x2 = min(item2._start.x, item2._end.x);
return x1 < x2;
[/code]
After calling std::sort, the elements are different then without calling sort, but it is still incorrect.
Results:
"T",169.000,11.438,169.000,14.438,"BO"
"P",240.000,42.000,217.000,42.000,""
"T",217.000,11.438,217.000,14.438,"BO"
"P",240.000,6.000,240.000,42.000,""
"T",25.000,11.438,25.000,14.438,"BO"
As you can see, the last element has a starting point of 25. This should not be the last element.
Any suggestions ?
Mike B
No idea of why, there is no way to tell without seeing more of your code.
Here is something that I think you want, HTH.
[code]
struct first_numeric_value
int ToInt(const std::string& str)
int x;
std::stringstream ss(str);
ss >> x;
return x;
int getFirstNumericValue(const std::string& StrArray)
std::string::size_type pos1 = StrArray.find(",");
std::string::size_type pos2 = StrArray.find(",",pos1+1);
return ToInt(StrArray.substr(pos1+1,pos2-pos1-1));
bool operator()(const std::string& lhs, const std::string& rhs)
return getFirstNumericValue(lhs) < getFirstNumericValue(rhs);
static void doSomeTest(void)
std::vector< std::string > myLst;
std::vector< std::string >::iterator it;
myLst.push_back( "\"T\",169.000,11.438,169.000,14.438,\"BO\"" );
myLst.push_back( "\"P\",240.000,42.000,217.000,42.000,\"\"" );
myLst.push_back( "\"T\",217.000,11.438,217.000,14.438,\"BO\"" );
myLst.push_back( "\"P\",240.000,6.000,240.000,42.000,\"\"" );
myLst.push_back( "\"T\",25.000,11.438,25.000,14.438,\"BO\"" );
std::sort( myLst.begin(), myLst.end(), first_numeric_value() );
for ( it = myLst.begin(); it != myLst.end(); ++it )
std::string s;
s = ( *it );
CString str( s.c_str() );
acutPrintf( _T("\n%s"), str );
myLst.clear();
[/code]
Then it will return an ascending sort of the vector:
Thanks for the reply. I noticed that you use std::vector, which is OK by me. Instead of using your code, I changed the application to use std::vector container instead of AcArray and it works as expected. Not sure why yet, but it works..
Thanks again.
Mike Bujak
oliver253
That's because std::sort() expects an iterator to the beginning of the container and another iterator to one past the end of the container, but AcArray::first() and AcArray::last() return references to the first/last element of the array, similar to vector's front() and back(); You can't use STL algorithms directly on an AcArray.
wrote in message news:[email protected]...
Why? It just needs to provide one past end iterator (pointer in this case).
AcArray has also the asArrayPtr() method. And you can use stl algorithms on
arrays 😉
oliver253
Completely forgot about that one,
std::sort( data.asArrayPtr(), data.asArrayPtr() + data.length() ) should indeed work nicely.
