ObjectARX
AcArray Assertion Failed
1 REPLY 1
268 Views, 1 Reply
In myCustomEnt.h
class myCustomEnt: public acdbcurve{
public:
    void CalSomething(void);
private:
    AcArray<Int32> mType;
in myCustomEnt.cpp
myCustomEnt::myCustomEnt(){   //Default Constructor
CalSomething(void);
void myCustomEnt::CalSomething(void){
  acutPrintf(_T("%d\n"), mType.length());  // mType.LogicalLength()=14 in the  initial input
  for (int i=0; i < Count; i++){   //Count = 14
       Int32 type = mType.at(i);
Acad::ErrorStatus myCustomEnt:: subTransformBy(...){
CalSomething(void);
The expected output should be 14 only in the comment screen.
But, I see the output
1
2
3
13
14
Why the AcArray LogicalLength unexpected changed? This will lead the assertion failed, if NDEBUG not defined.
What should I do to avoid this assertion failure?
Jack
1 REPLY 1
owenwengerd
The portion of the code that you posted is not complete and will not compile. I'm not sure I understand the problem, but if the size is not what you expect, then you should determine when and why it changed.
Owen Wengerd
ManuSoft
”Boost
