ObjectARX
[ACAD2013] Derive from AcDbBlockReference AcDbAttribute lots!
8 REPLIES 8
Message 1 of 9
gatti.massimo
921 Views, 8 Replies
Hi Everyone,
I create myCustomAcDbBlockReference class deriving the AcDbBlockReference in order to add custom snap points to blocks.
I successfully override the osnap protocol methods, but in my objects I loose the AcDbAttribute associated to the Block.
If I insert a block with an AcDbBlockReference I'm able to get all its attributes.
If I insert a block with my own AcDbBlockReference class I have no AcDbAttribute on it.
I lose them!
Should I Implement something in my child class? for example an iterator?
Thank you for your help!
Massimo
8 REPLIES 8
Message 2 of 9
owenwengerd
in reply to: gatti.massimo
AutoCAD's attributes are hard coded to work only with AcDbBlockReference and not with derived classes. Which versions of AutoCAD are you targeting? If only AutoCAD 2010 and later versions, you can use an overrule instead to add your custom snap points.
Owen Wengerd
ManuSoft
Message 3 of 9
Yes I'm using Autocad 2013.
How could I override the snappoints of a block?
Thank you!
Message 4 of 9
owenwengerd
You need to use the overrule API. Sorry, I don't have an example handy, but you can find plenty of information and even specific examples for adding snap points if you search.
Owen Wengerd
ManuSoft
Message 5 of 9
gatti.massimo
in reply to: owenwengerd
Ok, I looked at the overrules API and it seems the right way,
but
if I add an overrule on the AcDbBlockReference, the overrule will be used for ALL the blockreference added in my drawing?
I seen this example: http://adndevblog.typepad.com/autocad/2012/06/locking-an-entity-in-autocad-using-objectarx.html
Where I have to put my class definition? on the arx or on the dbx project?
Thank you for your help.
Message 6 of 9
Balaji_Ram
Here is a blog post on setting up a OSnap overrule for a block reference. The code is in C# but similar method also exist in C++.
http://adndevblog.typepad.com/autocad/2013/06/overruling-osnaps-of-blockreference.html
Hope this helps.
Balaji
Developer Technical Services
Autodesk Developer Network
Message 7 of 9
alex_b
Owen,
What about the inverse case: can one derive from AcDbAttribute in order to modify its behaviour, and use the custom entity in a regular AcDbBlockReference?
alex
Message 8 of 9
owenwengerd
in reply to: alex_b
I suspect it would work, but I don't know as I've never tried. Even if it works fine in most cases though, I wouldn't be surprised if there were some bugs or unexpected behaviors that result in certain circumstances.
Owen Wengerd
ManuSoft
Message 9 of 9
alex_b
Owen,
Thank you.
I'll give it a try.
alex
”Boost
