ObjectARX
[ACAD 2013] Zoom on object
4 REPLIES 4
gatti.massimo
1325 Views, 4 Replies
I need to zoom on an acdbBlockReference object.
I get the lowerleft and the upperright point for the zoom..
But how can I zoom on that area with the zoom command?
Thanks to everybody for your help!
This is my code
//zoom on object
			AcDbHandle			pObjHandle;
			AcDbObjectId		ObjId;
			AcDbObject		*	pObj;
			Acad::ErrorStatus	Err;
			pObjHandle = AcDbHandle(ActualNode->_ObjectHandleLow,ActualNode->_ObjectHandleHigh);
			acdbHostApplicationServices()->workingDatabase()->getAcDbObjectId(ObjId , false, pObjHandle);
			//recupero i dati del pnodedetails già presente
			if (acdbOpenAcDbObject(pObj, ObjId, AcDb::kForRead) != Acad::eOk)
				acutPrintf (_T("\nzoom - acdbOpenAcDbEntity error!"));
				//return;
			AcDbBlockReference * pBlockRef = AcDbBlockReference::cast(pObj);
			AcDbExtents block_extents;
			pBlockRef->getGeomExtents(block_extents);
			AcGePoint3d plLowerLeft, ptUpperRight; //-> it's your object extends coords
			plLowerLeft = block_extents.minPoint();
			ptUpperRight = block_extents.maxPoint();
4 REPLIES 4
oliver253m
in reply to: gatti.massimo
owenwengerd
Object extents are in World coordinates, but you need them in display coordinates for zooming. Just convert your handle to an ads_name (using acdbHandEnt), then use acedCommand to call the _ZOOM coomand's _Object option and provide the entity to zoom to.
Owen Wengerd
ManuSoft
gatti.massimo
in reply to: oliver253m
Perfect!
It works!
Thank you for your help!
minhasp
   m_ext is ACdbExtern of object;
    CString minPtstr;
    CString maxPtStr;
    minPtstr.Format(L"%.3f,%.3f",m_ext.minPoint().x,m_ext.minPoint().y);
    maxPtStr.Format(L"%.3f,%.3f",m_ext.maxPoint().x,m_ext.maxPoint().y);
    acedCommand(RTSTR,L"_ZOOM",RTSTR,L"_W",RTSTR,minPtstr,RTSTR,maxPtStr,RTNONE);
”Boost
