ObjectARX
ACAD 2013 - ObjectARX C++ - point line intersection
4 REPLIES 4
1165 Views, 4 Replies
I have to understand if a point is on a line.
What methods could I use?
I tried intersectwith(..)
but I can't read the acgepoint3darray...
Is there a simple method on acdbline to check this condition? for example with projections?
Thank you for your time.
Best regards
4 REPLIES 4
loic.jourdan
You can try
 - AcDbCurve::getParamAtPoint which returns an invalid error status if the input point is not on the curve.
 - AcDbCurve::getClosestPointTo and test if result point equals the input one
not sure which is the best, I guess the first one.
20-20 CAD / 20-20 Technologies
if your "givenPnt.isEqualTo(pointOnCurve)" after function usage point is on line )))
owenwengerd
The answer depends on what exactly you mean by "on a line". Since you mention projections, I wonder if you're trying to determine whether a projection of a point intersects a line.
Owen Wengerd
ManuSoft
in reply to: owenwengerd
for your answers.
"On a line", for me, means the point satisfy the equations which define the line and is between startpoint and endpoint.
”Boost
