I have to understand if a point is on a line.
What methods could I use?
I tried intersectwith(..)
but I can't read the acgepoint3darray...
Is there a simple method on acdbline to check this condition? for example with projections?
Thank you for your time.
Best regards
Solved by loic.jourdan. Go to Solution.
You can try
- AcDbCurve::getParamAtPoint which returns an invalid error status if the input point is not on the curve.
- AcDbCurve::getClosestPointTo and test if result point equals the input one
not sure which is the best, I guess the first one.
The answer depends on what exactly you mean by "on a line". Since you mention projections, I wonder if you're trying to determine whether a projection of a point intersects a line.
for your answers.
"On a line", for me, means the point satisfy the equations which define the line and is between startpoint and endpoint.
