I have developed a room as custom entity in AutoCAD 2010. So I can directly insert a room using this. This is a 2D representation.
Now my client has a requirement where I need to represent and edit the same room in 3D in AutoCAD. So there should be boolean operations possible with this.So that I can show windows, columns, Doors. It should be possible to drag a window in 3D to adjust its position.
This seems to be difficult with the current APIs available in AutoCAD, can any one give guidelines to achieve this functionality?
Advice about custom object architecture usually requires a detailed understanding of the project requirements, budget constraints, etc. You're more likely to get a response here if you post questions about a specific programming problem.
