.NET
ZoomWindow does not work
2 REPLIES 2
wesbird
268 Views, 2 Replies
I got a problem to ZoomWindow. What's wrong with the code?
Thank you.
[code]
[CommandMethod("Zoom_Test")]
static public void Zoom_Test()
Point3d ptll = new Point3d(0,0,0);
Point3d ptur = new Point3d(100,100,0);
Autodesk.AutoCAD.Interop.AcadApplication pApp;
pApp = (Autodesk.AutoCAD.Interop.AcadApplication) Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication;
// Object ll = (Object) ptll;
// Object ur = (Object) ptur;
// pApp.ZoomWindow(ll, ur);
pApp.ZoomWindow(ptll, ptur);
[/code]
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
2 REPLIES 2
phol
in reply to: wesbird
You need to use Double[] instead of Point3d, so the ToArray() function converts point3d to Double Array. See the code:
pApp.ZoomWindow(ptll.ToArray() , ptur.ToArray());
Pedro Henrique Liberato
wesbird
Thank you, It works great.
Wes
”Boost
