.NET
.NET
Valued Contributor
newautocad123
Message 1 of 5 (323 Views)
Zoom to the selected points extents or window.
323 Views, 4 Replies
12-06-2012 10:38 PM
In a dwg file there some features and and select some of them and want to zoom to that selected features extents only.
or how can I get the extents for that collection so that I can zoom to it.
Please suggest
Assuming ids is the selected entities objectId array and ed the current Editor
Here's a 'classical' way.
Using : ZoomObjects(ids)
 private void ZoomObjects(ObjectId[] ids)
Document doc = Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed = doc.Editor;
using (Transaction tr = db.TransactionManager.StartTransaction())
using (ViewTableRecord view = ed.GetCurrentView())
Matrix3d WCS2DCS =
(Matrix3d.Rotation(-view.ViewTwist, view.ViewDirection, view.Target) *
Matrix3d.Displacement(view.Target - Point3d.Origin) *
Matrix3d.PlaneToWorld(view.ViewDirection))
.Inverse();
Entity ent = (Entity)tr.GetObject(ids[0], OpenMode.ForRead);
Extents3d ext = ent.GeometricExtents;
for (int i = 1; i < ids.Length; i++)
ent = (Entity)tr.GetObject(ids[i], OpenMode.ForRead);
ext.AddExtents(ent.GeometricExtents);
ext.TransformBy(WCS2DCS);
view.Width = ext.MaxPoint.X - ext.MinPoint.X;
view.Height = ext.MaxPoint.Y - ext.MinPoint.Y;
view.CenterPoint =
new Point2d((ext.MaxPoint.X + ext.MinPoint.X) / 2.0, (ext.MaxPoint.Y + ext.MinPoint.Y) / 2.0);
ed.SetCurrentView(view);
tr.Commit();
 Here's a more generic one using extension methods for the Editor type (others zoom methods can be added to this class, calling or not the Editor.Zoom(Extents3d ext) one).
Using: ed.ZoomObjects(ids) // ids may be any type implementing IEnumerabe<ObjectId>
 static class ZoomExtensions
// Returns the transformation matrix from the ViewTableRecord DCS to WCS
public static Matrix3d EyeToWorld(this ViewTableRecord view)
return
Matrix3d.PlaneToWorld(view.ViewDirection);
// Returns the transformation matrix from WCS to the ViewTableRecord DCS
public static Matrix3d WorldToEye(this ViewTableRecord view)
return view.EyeToWorld().Inverse();
// Process a zoom according to the extents3d in the current viewport
public static void Zoom(this Editor ed, Extents3d ext)
ext.TransformBy(view.WorldToEye());
view.CenterPoint = new Point2d(
// Process a zoom objects in the current viewport
public static void ZoomObjects(this Editor ed, IEnumerable<ObjectId> ids)
using (Transaction tr = ed.Document.TransactionManager.StartTransaction())
Extents3d ext = ids
.Select(id => ((Entity)tr.GetObject(id, OpenMode.ForRead)).GeometricExtents)
.Aggregate((e1, e2) => { e1.AddExtents(e2); return e1; });
ed.Zoom(ext);
tr.Commit();
_gile
Message 2 of 5 (313 Views)
Re : Zoom to the selected points extents or window.
12-07-2012 12:44 AM in reply to: newautocad123
                Matrix3d WCS2DCS =
                    .Inverse();
                view.CenterPoint =
                tr.Commit();
            return
                Extents3d ext = ids
                ed.Zoom(ext);
                tr.Commit();
Gilles Chanteau
Valued Contributor
newautocad123
Message 3 of 5 (307 Views)
12-07-2012 01:28 AM in reply to: _gile
I tried to add object to the db and it did not work.
Thanks. It helped me lot.
_gile
Message 4 of 5 (300 Views)
12-07-2012 02:02 AM in reply to: newautocad123
Sorry I do not understand what you mean: "I tried to add object to the db and it did not work."
Gilles Chanteau
Valued Contributor
newautocad123
Message 5 of 5 (298 Views)
12-07-2012 02:34 AM in reply to: _gile
Your solution works well for me. What I had tried before posting this in the forum was the one below, which did not work. I was in the wrong track.
Thanks.
Transaction tr = Application.DocumentManager.MdiActiveDocument.TransactionManager.StartTransaction();
            using (tr)
                foreach (Autodesk.AutoCAD.DatabaseServices.ObjectId oId in oidList)
                    DBObject obj = tr.GetObject(oId, OpenMode.ForRead);
                    db.AddDBObject(obj);
                tr.Commit();
            Editor editor = Application.DocumentManager.MdiActiveDocument.Editor;
            ViewTableRecord view = new ViewTableRecord();
            Point3d center = db.Extmin + ((db.Extmax - db.Extmin) / 2);
            view.CenterPoint = new Autodesk.AutoCAD.Geometry.Point2d(center.X, center.Y);
            view.Height = db.Extmax.Y - db.Extmin.Y;
            view.Width = db.Extmax.X - db.Extmin.X;
            editor.SetCurrentView(view);
