.NET
Zoom to Objects
4 REPLIES 4
yaqiz
4110 Views, 4 Replies
Zoom to Objects
Hi All,
I try to write some code to zooom to objects but nothing happen.
Here is my Code
'--Pass array of Object ID
Public Function AutoCADZoomByObjectIDs(ByRef objObjectIDs() As ObjectId, _
                                     Optional ByVal dSizeUp As Double = 0) As Boolean
        Dim adblBottomLeft(2) As Double
        Dim adblTopRight(2) As Double
        Dim dblHighestY As Double
        Dim dblHighestX As Double
        Dim dblLowestY As Double
        Dim dblLowestX As Double
        Dim lngUBound As Long
        ' If the variant is not an array then exit the function
        If IsArray(objObjectIDs) = False Then Exit Function
        Dim objEd As Editor = acApp.DocumentManager.MdiActiveDocument.Editor
        Dim objEnt As Entity
        Dim objGExt As Extents3d
        Try
            Using objTrans As Transaction = objEd.Document.TransactionManager.StartTransaction
                objEnt = objTrans.GetObject(objObjectIDs(0), OpenMode.ForRead)
                objGExt = objEnt.GeometricExtents
                If dSizeUp = 0 Then dSizeUp = MathDistanceBetweenPoints(objGExt.MinPoint, objGExt.MaxPoint)
                dblLowestX = objGExt.MinPoint.X - dSizeUp
                dblLowestY = objGExt.MinPoint.Y - dSizeUp
                dblHighestX = objGExt.MaxPoint.X + dSizeUp
                dblHighestY = objGExt.MinPoint.Y + dSizeUp
                For lngCount As Long = objObjectIDs.GetLowerBound(0) + 1 To objObjectIDs.GetUpperBound(0)
                    objEnt = objTrans.GetObject(objObjectIDs(lngCount), OpenMode.ForRead)
                    If objGExt.MinPoint.X - dSizeUp < dblLowestX Then dblLowestX = objGExt.MinPoint.X - dSizeUp
                    If objGExt.MinPoint.Y - dSizeUp < dblLowestY Then dblLowestY = objGExt.MinPoint.Y - dSizeUp
                    If objGExt.MaxPoint.X + dSizeUp > dblHighestX Then dblHighestX = objGExt.MaxPoint.X + dSizeUp
                    If objGExt.MaxPoint.Y + dSizeUp > dblHighestY Then dblHighestY = objGExt.MaxPoint.Y + dSizeUp
                Next
                'Zoom to show this entire rectangle
                adblBottomLeft(0) = dblHighestX
                adblBottomLeft(1) = dblLowestY
                adblTopRight(0) = dblLowestX
                adblTopRight(1) = dblHighestY
'--g_objDrawing defined AcadDocument, it is the current open drawing. I have tested it is correct
 g_objDrawing.Application.ZoomWindow(adblBottomLeft, adblTopRight)
                objTrans.Commit()
                Return True
            End Using
        Catch ex As Exception
            Debug.Assert(False)
        Finally
            objEnt = Nothing
            objGExt = Nothing
            objEd = Nothing
        End Try
There is no exception, just nothing happen.
Any ideas?
Thanks very much
4 REPLIES 4
Jeffrey_H
in reply to: yaqiz
 [CommandMethod("ZoomToObjects")]
        public void ZoomToObjects()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            using (Transaction trx = doc.Database.TransactionManager.StartTransaction())
                PromptEntityOptions peo = new PromptEntityOptions("\nSelect Object: ");
                PromptEntityResult per = doc.Editor.GetEntity(peo);
                Entity ent = (Entity)per.ObjectId.GetObject(OpenMode.ForRead);
                int CvId = Convert.ToInt32((Application.GetSystemVariable("CVPORT")));
                using (Autodesk.AutoCAD.GraphicsSystem.Manager gm = doc.GraphicsManager)
                using (Autodesk.AutoCAD.GraphicsSystem.View vw = gm.GetGsView(CvId, true))
                        Extents3d ext = ent.GeometricExtents;
                        vw.ZoomExtents(ext.MinPoint, ext.MaxPoint);
                        gm.SetViewportFromView(CvId, vw, truetruefalse);
                trx.Commit();
*************************EDITED********************************
I do think this will work in paper space I check & if not I will post a better solution later
You can also find your answers @ TheSwamp
_gile
in reply to: Jeffrey_H
Here's one inspired by the sample in the AutoCAD .NET Developer's Guide > Control the AutoCAD Environment > Control the Drawing Windows > Zoom and Pan the Current View > Manipulate the Current View
It works whatever the current view.
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
namespace ZoomObjectSample
    public class Zoom
        [CommandMethod("ZO")]
        public void ZO()
            Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
            PromptSelectionResult psr = ed.GetSelection();
            if (psr.Status != PromptStatus.OK)
                return;
            ObjectIdCollection idCol = new ObjectIdCollection(psr.Value.GetObjectIds());
            ZoomObjects(idCol);
        private void ZoomObjects(ObjectIdCollection idCol)
            Database db = doc.Database;
            Editor ed = doc.Editor;
            using (Transaction tr = db.TransactionManager.StartTransaction())
            using (ViewTableRecord view = ed.GetCurrentView())
                Matrix3d WCS2DCS = Matrix3d.PlaneToWorld(view.ViewDirection);
                WCS2DCS = Matrix3d.Displacement(view.Target - Point3d.Origin) * WCS2DCS;
                WCS2DCS = Matrix3d.Rotation(-view.ViewTwist, view.ViewDirection, view.Target) * WCS2DCS;
                WCS2DCS = WCS2DCS.Inverse();
                Entity ent = (Entity)tr.GetObject(idCol[0], OpenMode.ForRead);
                ext.TransformBy(WCS2DCS);
                for (int i = 1; i < idCol.Count; i++)
                    ent = (Entity)tr.GetObject(idCol[i], OpenMode.ForRead);
                    Extents3d tmp = ent.GeometricExtents;
                    tmp.TransformBy(WCS2DCS);
                    ext.AddExtents(tmp);
                double ratio = view.Width / view.Height;
                double width = ext.MaxPoint.X - ext.MinPoint.X;
                double height = ext.MaxPoint.Y - ext.MinPoint.Y;
                if (width > (height * ratio))
                    height = width / ratio;
                Point2d center =
                    new Point2d((ext.MaxPoint.X + ext.MinPoint.X) / 2.0, (ext.MaxPoint.Y + ext.MinPoint.Y) / 2.0);
                view.Height = height;
                view.Width = width;
                view.CenterPoint = center;
                ed.SetCurrentView(view);
                tr.Commit();
Gilles Chanteau
GileCAD
GitHub
Hallex
in reply to: yaqiz
Give this a try for multiple objects
 using System.Linq;
   public static void ZoomObjects()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Transaction tr = doc.TransactionManager.StartTransaction();
            using (tr)
                try
                    PromptSelectionResult sres = ed.GetSelection();
                    if (sres.Status != PromptStatus.OK) return;
                    ObjectId[] ids = sres.Value.GetObjectIds();
                    if (ids.Length == 0) return;
                   int tile = Convert.ToInt32(Application.GetSystemVariable("CVPORT"));
                    var ents = from id in ids
                               where id != null
                               select tr.GetObject(id, OpenMode.ForRead);
                    var minx = (from n in ents
                                 where n != null
                                 select ((Entity)n).GeometricExtents.MinPoint[0]).Min();
                    var maxx = (from n in ents
                                where n != null
                                select ((Entity)n).GeometricExtents.MinPoint[0]).Max();
                    var miny = (from n in ents
                                where n != null
                                select ((Entity)n).GeometricExtents.MinPoint[1]).Min();
                    var maxy = (from n in ents
                                where n != null
                                select ((Entity)n).GeometricExtents.MinPoint[1]).Max();
                    Autodesk.AutoCAD.GraphicsSystem.Manager graph = doc.GraphicsManager;
                    using (graph)
                        Autodesk.AutoCAD.GraphicsSystem.View view = graph.GetGsView(tile, true);
                    using (view)
                        view.ZoomExtents(new Point3d(minx,miny,0),new Point3d(maxx,maxy,0));
                        view.Zoom(0.8);//<--optional
                        graph.SetViewportFromView(tile, view, true, true, false);
                  tr.Commit();
                catch (Autodesk.AutoCAD.Runtime.Exception ex)
                    ed.WriteMessage("Error: {0}\nTrace: {1}",ex.Message,ex.StackTrace);
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
LS67
in reply to: _gile
Just in case someone else has the same issue...
I tried Hallex's solution which is marked as the accepted solution. It did not work. Complete failure.
I tried Gilles's. It worked just fine. If it was me i would mark Gilles's solution as the Accepted one.
Yet another fine piece of code by Gilles.
”Boost
