.NET
*Tony Tanzillo
Message 11 of 14 (911 Views)
Re: Zoom Extents on new Database
09-20-2007 11:41 PM in reply to: Techno Destructo
Yes Mark, there is a way to "zoom a database"
In the case of a database that's not open in the
AutoCAD editor, "zoom" means to set the view
parameters to whatever is required to achieve
the desired view (e.g., the center, magnification,
direction, etc.).
If you think about it, AutoCAD must read something
in the drawing file to determine the initial view
when it opens the file (which for a drawing that was
previously open in the editor, is the view that was
current when the file was saved).
See this thread for the gory details:
http://discussion.autodesk.com/adskcsp/thread.jspa?messageID=5541432
For zooming to the extents, you could call the
UpdateExts() method of the Database, and then
read the Extmin and Extmax properties to get
the box that has to fit in the view. If the view
is not plan, then it becomes a bit more difficult.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2008
Supporting AutoCAD 2000 through 2008
http://www.acadxtabs.com
wrote in message news:5727528@discussion.autodesk.com...
Tony,
Is there a way to "zoom" a database?
I made my comment based on my attempts at doing just that. I browsed the object model but saw no zoom functionality associated with the databaseservices. I only found zoom used with the application object and that only effected the active document.
Am I missing something? I know that there are plenty of undocumented or otherwise hidden pieces to the programming puzzle.
By the way, your CommandLine.cs worked fine for zooming but again that would only work on the currently active drawing. Message was edited by: Discussion Admin
*Tony Tanzillo
Message 12 of 14 (911 Views)
See my reply to Mark.
wrote in message news:5727623@discussion.autodesk.com...
SO maybe zoom extents is not what I want.
Is there a way to specify the initial view on a new database.
The view is set by autocad when you create a new db can we change that default view I guess is the question?
Anyone know how?
Is it possible
New Member
cblais
Message 13 of 14 (912 Views)
07-13-2009 11:22 AM in reply to: Techno Destructo
Anyboby has a sample of code in paperspace ? This function works well in modelspace :
Sub ZoomExtents(ByVal myDB As Autodesk.AutoCAD.DatabaseServices.Database)
Dim tm As Autodesk.AutoCAD.DatabaseServices.Transaction = myDB.TransactionManager.StartTransaction
Try
If myDB.TileMode = True Then 'Model
Dim vpt As ViewportTable = tm.GetObject(myDB.ViewportTableId, OpenMode.ForRead)
Dim vptr As ViewportTableRecord = tm.GetObject(vpt.Item("*Active"), OpenMode.ForWrite)
Dim pt3Max As Point3d = myDB.Extmax
Dim pt3Min As Point3d = myDB.Extmin
Dim pt2Max As Autodesk.AutoCAD.Geometry.Point2d = New Autodesk.AutoCAD.Geometry.Point2d(pt3Max.X, pt3Max.Y)
Dim pt2Min As Autodesk.AutoCAD.Geometry.Point2d = New Autodesk.AutoCAD.Geometry.Point2d(pt3Min.X, pt3Min.Y)
vptr.CenterPoint = (pt2Min + (pt2Max - pt2Min) / 2.0)
vptr.Height = (pt2Max.Y - pt2Min.Y)
vptr.Width = (pt2Max.X - pt2Min.X)
myDB.UpdateExt(True)
Else 'Papier
End If
Catch ex As Exception
MsgBox("Erreur de zoom, " & ex.Message)
Finally
tm.Commit()
tm.Dispose()
End Try
End Sub
Valued Contributor
aksaks
Message 14 of 14 (768 Views)
01-10-2012 08:39 AM in reply to: cblais
Thanks cblais for the code. I needed to use it, but in order for this to work a myDB.UpdateExt(True) must be executed before retrieving the Extmax and Extmin values just as Tony Z stated on 9/20/07.
aks
