.NET
*Expert Elite*
_gile
Message 11 of 14 (160 Views)
Re : Y Direction
06-26-2013 06:25 AM in reply to: Amremad
From your last code, it seems to me that what you want to do is move the block reference about the current UCS Y axis with a value which is equal to:
BPoint.Y + (Val(attRef.TextString) - Val(BValue)) * Unit
 Try the code below (I remove some unuseful statements)
        Private Shared Sub ChangePostionLevel(MySelSet As SelectionSet, BPoint As Point3d, BValue As String, Unit As Double)
            Using Tr As Transaction = Application.DocumentManager.MdiActiveDocument.TransactionManager.StartTransaction()
                If MySelSet IsNot Nothing Then
                    For Each BlKID In MySelSet.GetObjectIds()
                        Dim BlkRef As BlockReference = Tr.GetObject(BlKID, OpenMode.ForWrite)
                        Dim objId As ObjectId = BlkRef.AttributeCollection.Item(0)
                        Dim attRef As AttributeReference = Tr.GetObject(objId, OpenMode.ForRead)
                        Dim yVal As Double = BPoint.Y + (Val(attRef.TextString) - Val(BValue)) * Unit
                        Dim disp As Vector3d = New Vector3d(0.0, yVal, 0.0)
                        disp = disp.TransformBy(Application.DocumentManager.MdiActiveDocument.Editor.CurrentUserCoordinateSystem)
                        BlkRef.TransformBy(Matrix3d.Displacement(disp))
                    Next
                Tr.Commit()
            End Using
        End Sub
Gilles Chanteau
Amremad
Message 12 of 14 (156 Views)
Re : Y Direction
06-26-2013 06:37 AM in reply to: _gile
know i know where is the problem
this is my correct code mr _gile
        Dim Tr As Transaction = Application.DocumentManager.MdiActiveDocument.TransactionManager.StartTransaction()
                Dim attRef As AttributeReference = Tr.GetObject(objId, OpenMode.ForWrite)
                Dim OPoint As Point3d = New Point3d(BlkRef.Position.X, BlkRef.Position.Y, BlkRef.Position.Z)
                ' Dim NPoint As Point3d
                Dim TDistance As Double = Math.Abs(BlkRef.Position.Y - BPoint.Y)
                Dim FDistance As Double
                If Val(attRef.TextString) > BValue Then
                    Dim PDistance As Double = (Val(attRef.TextString) - Val(BValue)) * Unit
                    If TDistance > PDistance Then
                        FDistance = -(TDistance - (PDistance))
                    Else
                        FDistance = TDistance + (PDistance)
                ElseIf Val(attRef.TextString) < BValue Then
                    Else
                        FDistance = TDistance - (PDistance)
                Else
                Dim disp As Vector3d = New Vector3d(0.0, FDistance, 0.0)
            Next
        Tr.Commit()
        Tr.Dispose()
    End Sub
 in the red line , the distance between block and base point in WCS , no problem
but when the code can't calcualte the distance in UCS  Correctly
so how can i get the distance between two point in any UCS or WCS Correctly
understand me
*Expert Elite*
_gile
Message 13 of 14 (151 Views)
Re : Y Direction
06-26-2013 07:05 AM in reply to: Amremad
It's really difficult to help you if the problem data changes with each message...
As I said, the BlockReference.Position is always defined in WCS coordinates, so if the 'BPoint' is not defined in WCS coordinates, you have to transform one of both so that they're defined in the same coordinate system before getting the distance between them.
The rest of your arithmetic could be simplified which would make the code more readable.
Gilles Chanteau
Amremad
Message 14 of 14 (131 Views)
Re : Y Direction
06-27-2013 02:58 AM in reply to: _gile
iam so sorry , but i work hard with this code:smileyhappy:
iam sorry
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
