.NET
Y Direction
13 REPLIES 13
Message 1 of 14
Amremad
1203 Views, 13 Replies
Y Direction
i need to calculate the distance between two point in new ucs
13 REPLIES 13
Message 2 of 14
_gile
in reply to: Amremad
Hi
The distance between 2 points is the same whatever the current UCS.
Gilles Chanteau
GileCAD
GitHub
Message 3 of 14
Amremad
in reply to: _gile
sorry i missed
i need to move the other point from any point in y direction
Message 4 of 14
_gile
To move an entity in the current UCS Y direction, you have to transform the y displacement vector with the current coodinate system before using this vector with the TransformBy() method.
Example to move the entity (ent) of 10 units in the UCS Y direction:
Vector3d disp = new Vector3d(0.0, 10.0, 0.0);
disp = disp.TransformBy(ed.CurrentUserCoordinateSystem);
ent.TransformBy(Matrix3d.Displacement(disp));
Gilles Chanteau
GileCAD
GitHub
Message 5 of 14
Amremad
in reply to: _gile
   Private Shared Sub ChangePostionLevel(MySelSet As SelectionSet, BPoint As Point3d, BValue As String)
        Dim Tr As Transaction = Application.DocumentManager.MdiActiveDocument.TransactionManager.StartTransaction()
        If MySelSet IsNot Nothing Then
            For Each BlKID In MySelSet.GetObjectIds()
                Dim BlkRef As BlockReference = Tr.GetObject(BlKID, OpenMode.ForWrite)
                Dim objId As ObjectId = BlkRef.AttributeCollection.Item(0)
                Dim attRef As AttributeReference = Tr.GetObject(objId, OpenMode.ForWrite)
                Dim OPoint As Point3d = New Point3d(BlkRef.Position.X, BlkRef.Position.Y, BlkRef.Position.Z)
                Dim NPoint As Point3d
                If attRef.TextString > BValue Then
                    'NPoint = New Point3d(BlkRef.Position.X, (BPoint.Y + (Val(attRef.TextString) - Val(BValue)) ), BlkRef.Position.Z)
                    Dim distance As Double = ""
                ElseIf attRef.TextString < BValue Then
                    NPoint = New Point3d(BlkRef.Position.X, (BPoint.Y - (Val(BValue) - Val(attRef.TextString))), BlkRef.Position.Z)
                ElseIf attRef.TextString = BValue Then
                BlkRef.TransformBy(Matrix3d.Displacement(OPoint.GetVectorTo(NPoint)))
            Next
        Tr.Commit()
        Tr.Dispose()
    End Sub
this funciton work correctly with normal ucs (world mode) , but doesn't work with other ucs
see this picture to understand what i want
Message 6 of 14
_gile
If you read attentively my previous reply, you can see the displacement vector is transformed by Editor.CurrentCoordinateSystem before beeing passed to the TransformBy() method.
Gilles Chanteau
GileCAD
GitHub
Message 7 of 14
Amremad
in reply to: _gile
    Private Shared Sub ChangePostionLevel(MySelSet As SelectionSet, BPoint As Point3d, BValue As String, Unit As Double)
                    NPoint = New Point3d(BlkRef.Position.X, (BPoint.Y + (Val(attRef.TextString) - Val(BValue)) * Unit), BlkRef.Position.Z)
                    NPoint = New Point3d(BlkRef.Position.X, (BPoint.Y - (Val(BValue) - Val(attRef.TextString)) * Unit), BlkRef.Position.Z)
                BlkRef.TransformBy(Application.DocumentManager.MdiActiveDocument.Editor.CurrentUserCoordinateSystem)
            Next
        Tr.Commit()
        Tr.Dispose()
    End Sub
like this ?????
it doens't work
Message 8 of 14
Amremad
it's very hard , please help me , if you need completely code , i will send it to you
Message 9 of 14
_gile
No, it is not "very hard", it's only some math logic.
You build a displacement vector from 2 points:
- the block reference insertion point (OPoint), BlockReference.Position returns a Point3d defined in WCS coordinates
- a point (NPoint) built from another one passed as argument to your function (BPoint)
The issue is: how is defined BPoint, WCS or UCS coordinates ?
If BPoint is defined in WCS coordinates, the displacement vector OPoint.GetVectorTo(Npoint) is defined too in WCS so you have to transform it:
Dim disp As Vector3d = OPoint.GetVectorTo(Npoint).TransformBy(ed.currentCoordinateSystem)
Esle if BPoint is defined in current UCS (as returned by Editor.GetPoint()), you have to transform OPoint from WCS to UCS before building the displacement vector. In this case, the displacement vector will be defined in UCS coordinates:
Dim disp As Vector3d = OPoint.TransformBy(ed.currentCoordinateSystem.Inverse()).GetVectorTo(Npoint)
 Then use this vector to Transform BlkRef...
Gilles Chanteau
GileCAD
GitHub
Message 10 of 14
Amremad
in reply to: _gile
                Dim disp As Vector3d = OPoint.TransformBy(Application.DocumentManager.MdiActiveDocument.Editor.CurrentUserCoordinateSystem.Inverse()).GetVectorTo(NPoint)
                BlkRef.TransformBy(Matrix3d.Displacement(disp))
            Next
        Tr.Commit()
        Tr.Dispose()
    End Sub
 also doesn't work
i think you will hit me Smiley Happy
i think iam failure , i can't understand ,
if you need the completley code to fix it tell me and i will send it for you
iam so sorry
Message 11 of 14
_gile
From your last code, it seems to me that what you want to do is move the block reference about the current UCS Y axis with a value which is equal to:
 Try the code below (I remove some unuseful statements)
            Using Tr As Transaction = Application.DocumentManager.MdiActiveDocument.TransactionManager.StartTransaction()
                        Dim attRef As AttributeReference = Tr.GetObject(objId, OpenMode.ForRead)
                        Dim yVal As Double = BPoint.Y + (Val(attRef.TextString) - Val(BValue)) * Unit
                        Dim disp As Vector3d = New Vector3d(0.0, yVal, 0.0)
                        disp = disp.TransformBy(Application.DocumentManager.MdiActiveDocument.Editor.CurrentUserCoordinateSystem)
                    Next
                Tr.Commit()
            End Using
        End Sub
Gilles Chanteau
GileCAD
GitHub
Message 12 of 14
Amremad
in reply to: _gile
know i know where is the problem
this is my correct code mr _gile
                ' Dim NPoint As Point3d
                Dim TDistance As Double = Math.Abs(BlkRef.Position.Y - BPoint.Y)
                Dim FDistance As Double
                If Val(attRef.TextString) > BValue Then
                    Dim PDistance As Double = (Val(attRef.TextString) - Val(BValue)) * Unit
                    If TDistance > PDistance Then
                        FDistance = -(TDistance - (PDistance))
                    Else
                        FDistance = TDistance + (PDistance)
                ElseIf Val(attRef.TextString) < BValue Then
                    Else
                        FDistance = TDistance - (PDistance)
                Else
                Dim disp As Vector3d = New Vector3d(0.0, FDistance, 0.0)
            Next
        Tr.Commit()
        Tr.Dispose()
    End Sub
 in the red line , the distance between block and base point in WCS , no problem
but when the code can't calcualte the distance in UCS  Correctly
so how can i get the distance between two point in any UCS or WCS Correctly
understand me
Message 13 of 14
_gile
It's really difficult to help you if the problem data changes with each message...
As I said, the BlockReference.Position is always defined in WCS coordinates, so if the 'BPoint' is not defined in WCS coordinates, you have to transform one of both so that they're defined in the same coordinate system before getting the distance between them.
The rest of your arithmetic could be simplified which would make the code more readable.
Gilles Chanteau
GileCAD
GitHub
Message 14 of 14
Amremad
in reply to: _gile
iam so sorry , but i work hard with this codeSmiley Happy
iam sorry
”Boost
