.NET
Xref Status
8 REPLIES 8
Message 1 of 9
696 Views, 8 Replies
Xref Status
Hi all,
Is there any way that I can find out the Xref Status in VB.NET? I am using ObjectDBX.
Please help.
8 REPLIES 8
Message 2 of 9
Look into the XrefGraph. I used it in a current drawing, but I would think
that you could use it with ObjectDBX.
Tim
"A blind man lets nothing block his vision."
wrote in message news:5301760@discussion.autodesk.com...
Hi all,
ObjectDBX.
Please help.
Message 3 of 9
Thanks Willey!
But I didn't find any example on XrefGraph. Please can you help me?
Message 4 of 9
Here is one I wrote with the help of Glenn R. over at theswamp.org
using System;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using acadApp = Autodesk.AutoCAD.ApplicationServices.Application;
[assembly: CommandClass (typeof(Test.Xref))]
namespace Test
/// Description of Xref.
public class Xref
[CommandMethod("XrGraphTest")]
static public void GraphTest()
Document ActDoc = acadApp.DocumentManager.MdiActiveDocument;
Database DocDb = ActDoc.Database;
Editor DocEd = ActDoc.Editor;
using (Transaction DocDbTrans = DocDb.TransactionManager.StartTransaction())
BlockTable DocDbBlkTbl =
(BlockTable)DocDbTrans.GetObject(DocDb.BlockTableId, OpenMode.ForRead);
XrefGraph DocDbXrGraph = DocDb.GetHostDwgXrefGraph(false);
for (int i = 0; i
XrefGraphNode XrGraphNode = DocDbXrGraph.GetXrefNode(i);
if (DocDbXrGraph.HostDrawing.Name == XrGraphNode.Name)
DocEd.WriteMessage("Drawing Name: {0}, In: {1}, Out: {2}", XrGraphNode.Name,
XrGraphNode.NumIn, XrGraphNode.NumOut);
else
DocEd.WriteMessage("Name: {0}, In: {1}, Out: {2}", XrGraphNode.Name,
if (XrGraphNode.NumOut > 0)
OutNodePrint1(XrGraphNode);
static public void OutNodePrint1(XrefGraphNode XrGraphNode)
for (int i = 0; i < XrGraphNode.NumOut; ++i)
XrefGraphNode tmpNode = XrGraphNode.Out(i) as XrefGraphNode;
if (tmpNode != null)
DocEd.WriteMessage(" {0}", tmpNode.Name);
else
DocEd.WriteMessage(" Not found as an "XrefGraphNode"!");
Tim
wrote in message news:5303614@discussion.autodesk.com...
Thanks Willey!
Message 5 of 9
I'm so sorry Willey, I am working in VB.Net. Hence the code didn't help me. But I tried converting it to VB, but in vein. Please help.
Message 6 of 9
Please can anybody give me an example of XrefGraphNode as I think that may help in what I am trying to do.
I have done the code to retrieve the xrefs and the XrefStatus. But if I want to change the path of a nested xref, it is not possible. What should I do?
Please help!
Message 7 of 9
This is my code:
Dim db As Autodesk.AutoCAD.DatabaseServices.Database
acadApp.DocumentManager.Open("C:\AR- 02- 202.dwg", False, Nothing)
db = New Database(False, False)
db.ReadDwgFile("C:\AR- 02- 202.dwg", IO.FileShare.ReadWrite, False, Nothing)
Dim tm As DBTransMan = db.TransactionManager
Dim ta As Transaction = tm.StartTransaction()
Dim bt As Autodesk.AutoCAD.DatabaseServices.BlockTable
Dim btr As BlockTableRecord
Dim blockId As ObjectId
Dim iter As IEnumerator
bt = ta.GetObject(db.BlockTableId, OpenMode.ForRead)
iter = bt.GetEnumerator()
Do While iter.MoveNext()
blockId = iter.Current
btr = ta.GetObject(blockId, OpenMode.ForWrite)
If btr.IsFromExternalReference Then
If btr.IsUnloaded = True Then
btr.PathName = "C:\$Blank.dwg"
btr.IsUnloaded = False
Loop
ta.Commit()
ta.Dispose()
db.SaveAs("C:\newtest.dwg", DwgVersion.Current)db.Dispose()
Please help as there is no documentation on this issue.
Message 8 of 9
I'm just starting in C#, and know nothing about VB. I come from a lisp
background. As per your other question, I don't think you can change the
path of a nested xref. The only way to do it, is to open up the top most
xref and change the xref in that drawing.
Tim
wrote in message news:5310461@discussion.autodesk.com...
Message 9 of 9
But we can repath nested xref in VBA. So it can also be done in VB.Net, I think.
”Boost
