.NET
Xref original file name of the drawing
1 REPLY 1
DouceDeux
434 Views, 1 Reply
Hello!
I'm trying to get just the filename either with or without the .dwg extension for an xref given I already have its reference (BlockReference) and its model space (BlockTableRecord) all open for read; skipping accessing any BlockTable.
Im doing something like this:
  • Either get the XGraph and first node or prompt user for a block reference and check it's from attachment
  • Start active document's database transaction, get the BlockReference.
  • Get the BlockTableRecord only with the BlockReference's BlockTableRecord-ObjectId property.
  • At this point I can iterate through the model space and see the nuts and bolts of the xref drawing without actually changing anything after saving my drawing, even after committing a trasaction.
So what I want to know is how to get the filename of the xref'ed drawing (i.e. Original_Drawing.dwg).
I'm looking at doing this without opening the referenced drawing as a side database and checking the filename.
I can't debug right now, but is it. myBlockTableRecord.Database.OriginalFileName ???
1 REPLY 1
Maybe this sample help you:
Finding all XREFs in the current database using C#.NET
Facebook | Twitter | LinkedIn
Expert Elite Member
”Boost
