.NET
Xref dependant LinetypeTableRecord and its database
2 REPLIES 2
RichardCammeray
421 Views, 2 Replies
I would like to ask for help to solve my problem with LinetypeTableRecord from Xref within attached drawings but you would probably need MgdBbg or ArxDbg to read their properties to help me (I appreciate that).
In Master.dwg there are two LinetypeTableRecords from X_source.dwg Xref:
1) X_source |CENTER
2) X_source |DASHED
Despite both LinetypeTableRecords are Xref dependant,  one linetype is Database  ‘Master.dwg’ resident  and second is Database ‘X_source.dwg’ resident.
After some investigation I thing autocad variable VISRETAIN  controls in what database the Xref linetypes are stored.
So my question and goal is:  how can I change/moved LinetypeTableRecord ‘X_source |DASHED’ from database ‘X_source.dwg’ to database ‘Master.dwg’ and keep property  IsDependant=true.
Sorry for clumsy explanation, I hope someone will help me.
Richard
2 REPLIES 2
jeff
in reply to: RichardCammeray
If that Linetype is assinged the Linetype of any layer in the xref then when its referenced its databse will be the local database.
If the linetype is not assigned to any layer  in the xref then its database will be the xref's
So yo answer your question make sure no layers in xref use that linetype.
You can also find your answers @ TheSwamp
RichardCammeray
in reply to: jeff
Thank you Jeff,
You are correct. But problem starts when you assign new linetype to some layer after attaching xref.
Then it seems to me that xref has to be reloaded with VISRETAIN=0 to make linetype local.
Richard
”Boost
