.NET
XData problem
3 REPLIES 3
899 Views, 3 Replies
XData problem
I have used Kean Walmsley's article http://through-the-interface.typepad.com/through_the_interface/2007/04/adding_xdata_to.html as a basis for trying to add xdata to a block.
I am trying to add the handle of another object to the block. Here is the code:-
   Private Sub Insert(ByVal tr As Transaction, ByVal Name As String, ByVal Path As String, _
                            ByVal Scale As Integer, ByVal ip As Point3d, ByVal Hwnd As Handle)
      Dim btr As BlockTableRecord = CType(tr.GetObject(CurDb.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
      Dim BlkId As ObjectId = CreateBlockReference(tr, Name, Path, btr)                '  insert blockreference
      Dim blk As BlockReference = New BlockReference(ip, BlkId)                        '  insert block
      blk.SetDatabaseDefaults()
      blk.ScaleFactors = New Scale3d(Scale, Scale, 1)
      blk.Rotation = 0
      btr.AppendEntity(blk)
      tr.AddNewlyCreatedDBObject(blk, True)                                            '  add it to transaction
      AddRegAppTableRecord(tr, "MYXDATA")
      Dim values() As TypedValue = {New TypedValue(1001, "MYXDATA"), New TypedValue(DxfCode.Handle, Hwnd)}
      Dim rb As New ResultBuffer(values)
      blk.XData = rb
      rb.Dispose()
   End Sub
   Private Sub AddRegAppTableRecord(ByVal tr As Transaction, ByVal regAppName As String)
      Dim rat As RegAppTable = DirectCast(tr.GetObject(CurDb.RegAppTableId, OpenMode.ForRead, False), RegAppTable)
      If Not rat.Has(regAppName) Then
         rat.UpgradeOpen()
         Dim ratr As New RegAppTableRecord()
         ratr.Name = regAppName
         rat.Add(ratr)
         tr.AddNewlyCreatedDBObject(ratr, True)
   End Sub
 I get the following error:- eInvalidInput
at the line blk.Xdata = rb
3 REPLIES 3
Alfred.NESWADBA
first guess:
don't use this: New TypedValue(DxfCode.Handle, Hwnd)
instead try this: New TypedValue(DxfCode.ExtendedDataHandle, Hwnd)
The DxfCode.Handle can only exist once for an object, and that's the object's handle, not a referenced handle from another entity.
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
dgorsman
in reply to: Alfred.NESWADBA
Let me guess - .Handle is DXF code 5, .ExtendedDataHandle is DXF code 1005?
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
in reply to: dgorsman
Smiley SurprisedOnly way to fly!
”Boost
