.NET
X-Ref Listing with RealDwg
1 REPLY 1
812 Views, 1 Reply
Is it possible to get a listing of all of the X-Refs contained in a particular document. I am attempting to do this with the following code: db.ReadDwgFile(testFileName, FileOpenMode.OpenForReadAndWriteNoShare, true, null); using (var tx = db.TransactionManager.StartTransaction()) { var xrefGraph = db.GetHostDwgXrefGraph(true); for(int i = 0; i < xrefGraph.NumNodes; i++) { XrefGraphNode xgn = xrefGraph.GetXrefNode(i); Console.WriteLine(xgn.Name); } } I know that this drawing has 3 attached X-Refs, but none are coming up in the node graph. Any ideas of what I may be doing wrong? Thanks and Regards, Sean Hunter
Tags (2)
1 REPLY 1
philippe.leefsma
XRefs are accessed in RealDWG the exact same way than in AutoCAD. You first need to call "Database.ResolveXrefs" and of course to have those referenced documents physically present on your disk. They won't get resolved otherwise...
Here is an AutoCAD command. RealDWG code will be the same, except you don't have Document, Editor and you get the database using HostApplicationServices.WorkingDatabase:
[CommandMethod("XrefGraph")]
public static void XrefGraph()
    Document doc = Application.DocumentManager.MdiActiveDocument;
    Database db = doc.Database;
    Editor ed = doc.Editor;
    using (Transaction Tx = db.TransactionManager.StartTransaction())
        db.ResolveXrefs(true, false);
        XrefGraph xg = db.GetHostDwgXrefGraph(true);
        for (int i = 1; i < xg.NumNodes; ++i)
            XrefGraphNode node = xg.GetXrefNode(i);
            if (node.XrefStatus == XrefStatus.Resolved)
                BlockTableRecord btr = Tx.GetObject(node.BlockTableRecordId, OpenMode.ForRead) as BlockTableRecord;
                ed.WriteMessage("\n---------------------");
                if (btr.IsFromExternalReference == true)
                    ed.WriteMessage("\nXref path name: " + btr.PathName);
                ed.WriteMessage("\nName of Xref (Found name): " + node.Database.Filename);
Philippe Leefsma
Developer Consultant
Developer Technical Services
Global Subscription & Support
www.autodesk.com/joinadn
Philippe Leefsma
Autodesk Developer Network
”Boost
