.NET
wtypes.h': No such file or directory
6 REPLIES 6
2860 Views, 6 Replies
I'm trying to work through the ObjectARX tutorial (Step 1), (Visual C++ 2005
Express edition)
I've manage to complete all the steps but when I build I get the following
error
"c:\objectarx 2006\inc\accmd.h(74) : fatal error C1083: Cannot open include
file: 'wtypes.h': No such file or directory"
so I figure I've typed something gin wrong and through I would try and
download the solved solution,
but guess what the same error message?
Am I missing some files, or can't I use the express edition?
Cheers
Ant
6 REPLIES 6
NathTay
If it is ObjectARX not a program using the .NET API then you can only use a specific version of Visual Studio. It should be specified in the help file.
Regards - Nathan
cgay
This was posted in reply to another issue, but it looks like it might provide some information for your issue as well.
Reply From: Bill Hashman
Date: Jan/30/06 - 17:27 (EST)
Re: Debugger Stop Working After install Visual Studio 2005.
See comments here:
http://www.manusoft.com/Resources/ARXTips/Index.stm
Are the header files available for download?
I'm looking for an sdk that contains wtypes.h
wrote in message news:5073713@discussion.autodesk.com...
See comments here:
cgay
Anthony,
Look Here
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=773204
I've already got the complete sdk
but I still can't find wtypes.h in the folder
This is a M$ file, not an autodesk one.
Chris Arps
”Boost
