.NET
Without open dwg get GETSYSTEMVARIABLE("TDCREATE")?
10 REPLIES 10
Message 1 of 11
1015 Views, 10 Replies
Is it possible to Get Create Date and Time without open drawing using GETSYSTEMVARIABLE("TDCREATE")?
ie. Open drawing in memory and Receive Date and Time.
Give me suggestion.
thenndral
10 REPLIES 10
Message 2 of 11
Ajilal.Vijayan
Try this .
 Dim Side_dbase As Database = New Database(False, True)
 Dim EX As Autodesk.AutoCAD.Runtime.Exception = New Autodesk.AutoCAD.Runtime.Exception
        Try
            Side_dbase.ReadDwgFile("FileName", FileOpenMode.OpenForReadAndWriteNoShare, True, "")
            MsgBox(Side_dbase.Tdcreate)
            Side_dbase.Dispose()
        Catch ex
        End Try
Message 3 of 11
in reply to: Ajilal.Vijayan
Hi Ajilal.Vijayan,
Thanks for your quick reply. Its works like a charm.
one more question. Is it possible to get millisecond from TDCREATE or other method?
I'm using C#, convert it into C#.
Here is the code for C# user[It may be helpful for someone]
        [CommandMethod("TTS")]
        public void Time_tracking()
            Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
            Database Side_dbase = new Database(false, true);
            Autodesk.AutoCAD.Runtime.Exception EX = new Autodesk.AutoCAD.Runtime.Exception();
            try
                string blockQualifiedFileName = "D:\\AutoCAD\\testing\\time_chk.dwg";
                Side_dbase.ReadDwgFile(blockQualifiedFileName, FileOpenMode.OpenForReadAndWriteNoShare, true, "");
                AcadApp.ShowAlertDialog("Created:" + Side_dbase.Tdcreate);
                Side_dbase.Dispose();
            catch
Thanks in advance,
Thenndral.
Message 4 of 11
Ajilal.Vijayan
Try this
 MsgBox(Side_dbase.Tdcreate.ToOADate + 2415018.5)
Message 5 of 11
Thanks for your reply.
If I use the code. It retrieves Date in double.
AcadApp.ShowAlertDialog("Created :" + tmp_db.Tdcreate.ToOADate() + 2415018.5);
Please check the image file for retrieve result .
I convert Julian Date using below code. This code can convert upto seconds.
Could you tell me how to make in milliseconds.
        private DateTime ConvertAcadJulianToDateTime(double julianDate)
            DateTime date;
            try
                double z = Math.Floor(julianDate);
                double w = Math.Floor((z - 1867216.25) / 36524.25);
                double x = Math.Floor(w / 4);
                double a = (z + 1 + w - x);
                double b = a + 1524;
                double c = Math.Floor((b - 122.1) / 365.25);
                double d = Math.Floor(365.25 * c);
                double e = Math.Floor((b - d) / 30.6001);
                double f = Math.Floor(30.6001 * e);
                int day = Convert.ToInt32(b - d - f);
                int m = Convert.ToInt32((e < 14) ? (e - 2) : (e - 14));
                int month = (m + 1);
                int y = Convert.ToInt32((m > 1) ? (c - 4716) : (c - 4715));
                int year = (y == 0) ? (y - 1) : y;
                // strip the integer
                double t = (julianDate - z);
                // hours since midnight
                double hours = Math.Floor(t * 24.0);
                // temp value
                double mins = t - (hours / 24.0);
                // 1440 minutes per day
                double minutes = Math.Floor(mins * 1440.0);
                double seconds = Math.Floor((mins - (minutes / 1440.0)) * 86400.0);
                //86400000 = 1day
                date = new DateTime(year, month, day, Convert.ToInt32(hours), Convert.ToInt32(minutes), Convert.ToInt32(seconds));
                return date;
            catch (ArgumentOutOfRangeException ex)
                AcadApp.ShowAlertDialog("Julian date could not be converted:\n" +  ex.Message);
                date = new DateTime(0);
            catch (Exception ex)
                AcadApp.ShowAlertDialog("Error converting Julian date:\n" + ex.Message);
            return date;
Thanks in advance,
thenndral
Message 6 of 11
Ajilal.Vijayan
Try with this function
jul = tmp_db.Tdcreate.ToOADate() + 2415018.5)
  Private Function Getmilsecond(ByVal jul As Double)
        Dim mil As Double
        Dim time As Double = (jul - Math.Floor(jul)) * 86400
        Dim mm As Double = Math.Floor(time / 60)
        mil = time - (mm * 60)
        Return mil
    End Function
Message 7 of 11
In my previous post code I can retrieve seconds from Julian date.
                //86400000 = 1day
In this code I'm getting seconds not milliseconds.
private object Getmilsecond(double jul)
    double mil = 0;
    double time = (jul - Math.Floor(jul)) * 86400;
    double mm = Math.Floor(time / 60);
    mil = time - (mm * 60);
    return mil;
I need how to get millisecond from Julian Date.
for more information, Please see the image.
Thanks in advance,
thenndral
Message 8 of 11
Ajilal.Vijayan
 That function will return the seconds from julian date with milliseconds
See the below results from a test drawing
Out from the funtion.
and output of autocad TIME command
Message 9 of 11
Thanks a lot for your quick reply and solution.
I got it.
I accept your solution.
Thanks again,
thenndral.
Message 10 of 11
Ajilal.Vijayan
I got it.
Thanks again,
thenndral.
Glad to hear that !!
Message 11 of 11
Can I get a copy of your app? I'd love to be able to quickly check TDCREATE values without having to open the dwgs. Thanks!
”Boost
