.NET
Distinguished Contributor
0 Kudos
Post 1 of 3
WinForm dialog box
221 Views, 2 Replies
10-07-2005 08:14 AM
I have some questions about the dialog box in .Net(C#):
a. when I run a dialog box, it will show a seperate item on the status bar which VBA did not. What should I do to make it disappear?
b. in the properties of Form(dialog box), under FormBorderStyle:
what the difference between FixedDialog and Fixed Single?
Thank you
Wes
Vault Pro 2014, Windows 7 64 bit, AutoCAD (ACA, Map) 2014
*J. Daniel Smith
Post 2 of 3
Re: WinForm dialog box
10-07-2005 12:10 PM in reply to: wesbird
These have nothing to do with AutoCAD:
a.
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/cpref/html/frlrfSystemWindowsFormsFormClassShowInTaskbarTopic.asp?frame=true
b.
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/cpref/html/frlrfsystemwindowsformsformborderstyleclasstopic.asp
Note that you should use
Autodesk.AutoCAD.ApplicationServices.Application.ShowModalDialog() (or
ShowModelessDialog()) to display your dialog.
Dan
wrote in message news:4978598@discussion.autodesk.com...
Thank you
Wes
0 Kudos
Post 3 of 3
10-07-2005 12:15 PM in reply to: wesbird
Thank you,
