.NET
Window Jump!
2 REPLIES 2
ElephantQi
293 Views, 2 Replies
Window Jump!
I use VB.NET design 4 windows for user input in AutoCad, when I hit the next button on the 1st window, then the 2nd window jump out, however, it jumps out behind the Autocad main window. the window 3 and 4 works fine. Is there anyone knows how to fix this little BUG?
Thank you in advanced!
I use VS2010 and AutoCad2011
I use the following to get the 1st window.
<CommandMethod("CoreInput")> _
Public Sub ShowForm()
        Dim ModalForm As Form1 = New Form1()
        Autodesk.AutoCAD.ApplicationServices.Application.ShowModalDialog(ModalForm)
    End Sub
use the following to hide the 1st window and jump out the 2nd window.
Private Sub Button1_Click(ByVal sender As Object, ByVal e As System.EventArgs) Handles Button1.Click
        Dim Form2Open As New Form2
        Form2Open.Show()
        'Form2.Show()
        Me.Hide()
    End Sub
2 REPLIES 2
HJohn1
in reply to: ElephantQi
Why you do not use the Aplication.ShowModalDialog method on your Button_Click event as you did on your Command method?  You are not supposed to call the Form.Show methods directly because it could result in unexpected behavior.
ElephantQi
in reply to: HJohn1
It fixed, thanks John!Smiley Wink
”Boost
