.NET
Distinguished Contributor
area51visitor
Message 1 of 19 (439 Views)
Will the best code reviewer please stand up
439 Views, 18 Replies
03-05-2013 08:02 PM
Just hoping someone will review my code below and offer advice for improvements. Basically want to learn. Thanks!!!
// send wipeouts to back
namespace BCCWIPEBACK
    public class DraftingTools
        [CommandMethod("BCC:WBACK")]
        public static void BCCWIPETOBACK()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Transaction tr = db.TransactionManager.StartTransaction();
            using (tr)
                BlockTable bt = tr.GetObject(db.BlockTableId, OpenMode.ForWrite) as BlockTable;
                foreach (ObjectId objId in bt)
                    BlockTableRecord btr = objId.GetObject(OpenMode.ForWrite) as BlockTableRecord;
                    foreach (ObjectId btrObjId in btr)
                        Entity ent = btrObjId.GetObject(OpenMode.ForWrite) as Entity;
                        if (ent is Wipeout)
                            DrawOrderTable drawOrder = tr.GetObject(btr.DrawOrderTableId, OpenMode.ForWrite) as DrawOrderTable;
                            ObjectIdCollection ids = new ObjectIdCollection();
                            ids.Add(ent.ObjectId);
                            drawOrder.MoveToBottom(ids);  //move the selected entity so that entity is drawn in the beginning of the draw order.
                } tr.Commit();
- Brian
"Very funny, Scotty. Now beam down my clothes."
Please compare:
using (Transaction tr = db.TransactionManager.StartTransaction()) {
BlockTable bt = tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
if (bt != null) {
foreach (ObjectId objId in bt) {
BlockTableRecord btr = objId.GetObject(OpenMode.ForRead) as BlockTableRecord;
if (btr != null) {
foreach (ObjectId btrObjId in btr) {
if (btrObjId.ObjectClass.IsDerivedFrom(RXClass.GetClass(typeof(Wipeout)))) {
ids.Add(btrObjId);
// Old versions of AutoCAD .NET API has not ObjectId.ObjectClass method. So:
// Entity ent = btrObjId.GetObject(OpenMode.ForRead) as Entity;
// if (ent != null && ent is Wipeout) {
// ids.Add(btrObjId);
if (ids.Count > 0) {
if (drawOrder != null) {
// Why MoveToBottom()? In this case wipeouts
// do not hide entities. Maybe use MoveToTop() instead?
// drawOrder.MoveToTop(ids);
tr.Commit();
doc.Editor.Regen();
Moderator
Alexander.Rivilis
Message 2 of 19 (411 Views)
Re: Will the best code reviewer please stand up
03-06-2013 01:32 AM in reply to: area51visitor
Please compare:
        if (bt != null) {
            if (btr != null) {
                  ids.Add(btrObjId);
        tr.Commit();
      doc.Editor.Regen();
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
area51visitor
Message 3 of 19 (395 Views)
03-06-2013 04:02 AM in reply to: area51visitor
Thanks Alexander (Alex ok?)!  You are awesome!
I really appreciate it... the "if" statements obviously stand out (on my phone that is lol), but will definately study it more the next few days.
Really appreciate your help.
- Brian
Moderator
Alexander.Rivilis
Message 4 of 19 (394 Views)
03-06-2013 04:07 AM in reply to: area51visitor
bcinnv wrote:
...Alex ok?...
OK!
Distinguished Mentor
BlackBox_
Message 5 of 19 (356 Views)
03-06-2013 01:48 PM in reply to: Alexander.Rivilis
Hi Alexander,
Would it not be better to use StartOpenCloseTransaction() in lieu of StartTransaction()?
Also, since the Database is being modified, shouldn't a DocumentLock wrap the Transaction's using statement?
"Potential has a shelf life." - Margaret Atwood
Autodesk Exchange Apps ~ Autoloader ~ AutoCAD Security
Moderator
Alexander.Rivilis
Message 6 of 19 (344 Views)
03-06-2013 02:59 PM in reply to: BlackBox_
This is a complex question. Possible and so and so. My preference - native ObjectARX and smart pointers. :smileyhappy:
No. As far as this function is the command handler, and this command working in document context (has not CommandFlag.Session flag) In this case, AutoCAD itself locks the document before command start and unlocks after its stop.
BlackBox_
Message 7 of 19 (337 Views)
03-06-2013 03:18 PM in reply to: Alexander.Rivilis
Thanks for that clarification, Alexander... I did have a separate question, though, if I may?
Why iterate the entire BlockTable, when one could iterate a simple SelectionSet?
Pseudo-code (tested):
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
using acApp = Autodesk.AutoCAD.ApplicationServices.Application;
namespace Autodesk.Forums.PseudoCode.DraftingTools
    public class Commands
        [CommandMethod("WBACK")]
        public static void WipeOutToBack()
            Document doc = acApp.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            TypedValue[] tvs = new TypedValue[]
                new TypedValue((int)DxfCode.Start, "WIPEOUT")
            SelectionFilter filter = new SelectionFilter(tvs);
            PromptSelectionResult psr = ed.SelectAll(filter);
            if (psr.Status == PromptStatus.OK)
                using (Transaction trans =
                        db.TransactionManager.StartOpenCloseTransaction())
                    SelectionSet ss = psr.Value;
                    ObjectId[] ids = ss.GetObjectIds();
                    foreach (ObjectId id in ids)
                        Entity ent =
                            trans.GetObject(id, OpenMode.ForRead) as Entity;
                            trans.GetObject(ent.BlockId, OpenMode.ForRead) as BlockTableRecord;
                            trans.GetObject(btr.DrawOrderTableId, OpenMode.ForWrite) as DrawOrderTable;
                        ObjectIdCollection idToMove = new ObjectIdCollection();
                        idToMove.Add(id);
                        drawOrder.MoveToBottom(idToMove);
                    ed.WriteMessage("\n** Wipeout(s) sent to back ** ");
                    trans.Commit();
            else
                ed.WriteMessage("\n** No wipeout(s) found ** ");
Valued Mentor
DiningPhilosopher
Message 8 of 19 (321 Views)
03-06-2013 06:19 PM in reply to: BlackBox_
Pseudo-code (tested):......
<snip>
You might want to review your code.
First, you open the same DrawOrderTable for every entity in the selection.
Second, you are calling MoveToBottom() once for every entity in the selection.
Third, you are not modifying the WIPEOUT objects in the selection, and don't need to open them in the first place, because they are all WIPEOUT objects.
So....
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
namespace Autodesk.AutoCAD.ApplicationServices.MyExtensions
   public static class WipeOutOrderExample
      [CommandMethod( "WIPEOUTORDER" )]
      public static void WipeOutOrderCommand()
         TypedValue[] array = new TypedValue[] {
            new TypedValue(0, "WIPEOUT")};
         PromptSelectionResult psr = ed.SelectAll( new SelectionFilter( array ) );
         if( psr.Status != PromptStatus.OK || psr.Value.Count == 0 )
            ed.WriteMessage( "\nNo editable WIPEOUT objects found." );
            return;
         ed.WriteMessage( "\n{0} WIPEOUTs found,", psr.Value.Count );
         PromptKeywordOptions pko = new PromptKeywordOptions( "\nMove to Top or Bottom?" );
         pko.Keywords.Add( "Top" );
         pko.Keywords.Add( "Bottom" );
         pko.Keywords.Default = "Bottom";
         PromptResult pr = ed.GetKeywords( pko );
         if( pr.Status != PromptStatus.OK )
            return;
         bool top = pr.StringResult == "Top";
         using( Transaction tr = doc.TransactionManager.StartTransaction() )
            ObjectIdCollection ids = new ObjectIdCollection( psr.Value.GetObjectIds() );
            BlockTableRecord btr = (BlockTableRecord)
               tr.GetObject( doc.Database.CurrentSpaceId, OpenMode.ForRead );
            DrawOrderTable dot = (DrawOrderTable)
               tr.GetObject( btr.DrawOrderTableId, OpenMode.ForWrite );
            if( top )
               dot.MoveToTop( ids );
            else
               dot.MoveToBottom( ids );
            tr.Commit();
            doc.Editor.WriteMessage( "Modified draw order of {0} WIPEOUTs", ids.Count );
area51visitor
Message 9 of 19 (316 Views)
03-06-2013 06:40 PM in reply to: area51visitor
Thank you! sorry... I should clarify the purpose of the code is to deal with a glitch I've had since I moved to windows 7 / 64bit system, and Civil 3d. Wipeouts randomly jump to the top of the objects. Such as textmasks. Instead of hiding what's under the text...the draw order randomly reverses, and hides everything. Often it's a problem due to locked layers, but that's not always the case.
When I manually set the draw order for the wipeouts by selecting them all, I no longer have that problem.  What I've been doing is sending the wipeouts to the back, then my xrefs. It's worked well so far.
Sorry for the confusion.
- Brian
BlackBox_
Message 10 of 19 (311 Views)
03-06-2013 07:03 PM in reply to: DiningPhilosopher
//<snip>
How very inefficient of me (oops); thanks for the correction....
That was a kludge thrown together for me to learn from (and that I have, thank you) right as I was leaving the office, as every single ADN DevBlog example only showed how to modify the draw order for single entity selection... Couldn't find one modifying SelectionSet.
Admittedly, I overlooked passing SelectionSet.GetObjectIds() to DrawOrderTable.MoveTo*(). Thanks for the clarification, and code as an example.
Now that that's out of the way, I am correct in that (logically) it is better to perform this task on a valid SelectionSet, rather than iterating the BlockTable, no?
Cheers!
Edit to add:
"Third, you are not modifying the WIPEOUT objects in the selection, and don't need to open them in the first place, because they are all WIPEOUT objects."
The code I posted (never mind the duplication of work) _did_ modify the Wipeout entities (not express tools text masks, WIpeouts)... My test was performed on a line drawn with a Wipeout drawn over the top such that part of the line was no longer visible. The code (albeit innefficiently) correctly moved the Wipeout(s) to the back so that the line was fully visible.
If I've misunderstood your point, please clarify.
Autodesk Alert | We are currently working on restoring Previous Version License request access in the Autodesk Subscription Center. If you are a subscription customer and would like to request a Previous Version License, please use this link as a temporary workaround. We apologize for the inconvenience and thank you for your patience.
