.NET
Why there is no Rotate and Rotate3d method in .NET
3 REPLIES 3
wesbird
321 Views, 3 Replies
Hi
I found Rotate and Rotate3d both exist in VBA (ActiveX) and ObjectARX, but not in .NET?
Do I miss something in .NET?
How I rotate in 3d without COM Interop?
Thank you
Wes
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
3 REPLIES 3
jbooth
in reply to: wesbird
This is just a guess, but can't you create a rotation matrix and multiply it through?
Dim m As Matrix3d = Matrix3d.Rotation(angle, rotationVector, centrePoint)
For Each ent As Entity In objectsToRotate
ent.TransformBy(m)
Next ent
The reason they don't add the functionality is probably because you can do it easily enough yourself, (but only if you understand euclidean mathematics I guess).
This way, it's not necessary for them to add anything at all, since you can
do everything yourself.
Why not write your own operating system and pay for it in the bargain?
wrote in message news:5124556@discussion.autodesk.com...
through?
ent.TransformBy(m)
Next ent
I guess).
Those have kinda been moved to the Matrix2d and Matrix3d classes. If you need to construct scaling/rotation/etc, you do that with the matrix then apply to the entities ecs.
Example : There is no "Move" method, but this shows how to do it.
Dim fromPt As Point3d
Dim toPt As Point3d
Dim ptRes As PromptPointResult
ptRes = editor.GetPoint("Pick a from point")
If ptRes.Status <> PromptStatus.OK Then Return
fromPt = ptRes.Value
ptRes = editor.GetPoint("Pick a to point")
toPt = ptRes.Value
Dim moveVec As New Vector3d(toPt.X - fromPt.X, toPt.Y - fromPt.Y, toPt.Z - fromPt.Z)
Dim moveMat As Matrix3d = Matrix3d.Displacement(moveVec)
ent.TransformBy(ent.Ecs.PostMultiplyBy(moveMat))
Chris Arps
”Boost
