.NET
Distinguished Contributor
JanetDavidson
Message 1 of 3 (143 Views)
Which one of these transactions is right. I am confused when we need to commit?
143 Views, 2 Replies
07-10-2012 10:08 PM
Hi  gentlemen, see 2 functions below please. Which one is right ? Shall I commit Transaction or Not? I don't get any error at all in both cases but like to know what is right.
Function  Test() as Boolean
  Using tr As Transaction = Mydwg.TransactionManager.StartTransaction
     If BlahBlah = BlahBlahBlah Then
            Return True
     End If
  tr.Commit()
  End Using
  Return False
End Function
Function  Test1() as Boolean
         tr.commit
         Return True
     End If
  tr.Commit()
  End Using
  Return False
End Function
Hopefully, there is something else going on inside your If block, or you don't need the transaction at all.  That said, in function Test, if BlahBlah = BlahBlahBlah then the transaction will not be committed, because the function returns before hitting the commit.  The only way you could not notice this in your real code is if the transaction is read only (or if you really don't need the transaction at all), otherwise you would see that whatever changes your code made were reverted.  Read-Only transactions should always be committed, because if you do not call commit, then when the transaction is disposed (at your End Using) tr.Abort is automatically called, and tr.Abort carries more overhead than tr.commit.
chiefbraincloud
Message 2 of 3 (121 Views)
Re: Which one of these transactions is right. I am confused when we need to comm
07-11-2012 09:05 AM in reply to: JanetDavidson
JanetDavidson
Message 3 of 3 (97 Views)
07-12-2012 03:18 PM in reply to: chiefbraincloud
Thank you very much for explanation , I go with Test1 function then.
Cheers.
Janet.
