.NET
Which assembly does Autodesk.AutoCAD.DatabaseServices.ImpObject belong to?
1 REPLY 1
252 Views, 1 Reply
I find that the type of a custom object is IAutodesk.AutoCAD.DatabaseServices.ImpObject.But which assembly does this class belong to?
Thanks in advance!
1 REPLY 1
acdbmgd.dll is the assembly.
Regarding this type, I tripped over it too.
The ObjectModified and related events of the
Database routinely throw instances of this type
at the handler, but you must not try to access
them at all because they're not exported types.
So:
// a handler for the Database.ObjectModified event:
database_ObjectModified(DBObject obj)
if( obj.GetType().IsNotPublic )
return;
// else do your stuff
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2008
Supporting AutoCAD 2000 through 2008
http://www.acadxtabs.com
wrote in message news:5544709@discussion.autodesk.com...
Thanks in advance!
”Boost
