.NET
Where to start?
2 REPLIES 2
wesbird
213 Views, 2 Replies
Where to start?
This is my first time here. I have built a in-house project in VBA for 6 months. I use a lot of functions in CAO (dbConnect). Now the company I work for plan to sell it. Now I have some questions:
I'm required make my routine work with another component which wrote by another programmer in .Net. It will be good if I migrate my code to .Net. So what kind of method I should go with:
a. if I plan to make my routine work with 2004, I have to use COM and interop. if 2006, I can use some neat, power, AutoCAD built-in .Net functions. so beside the market popularity, what other factor should I consider?
b. Which version of Visual Studio .NET should I start, 2002, 2003, or 2005? is 2005 Express version good for production?
c. which language should I go for, VB.NET or C#?
d. Instead of rewriting all the code, is there any easy way to migrate VBA code to VB.NET? I don't think cut_n_paste will work, is it correct? How long it properly take at least?
e. Is there anybody work with CAO in .NET? I can not find any documentation in the ObjectARX Reference. Is there any sample?
Thank you in advance
Wes Message was edited by: weslleywang
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
2 REPLIES 2
NathTay
in reply to: wesbird
If your programming background is VBA I would choose VB.NETand have a look at this free book from Microsoft. http://msdn.microsoft.com/vbrun/staythepath/additionalresources/upgradingvb6/
Basically I would choose the language with the syntax you like.
If you will still be using the ActiveX API you should be able to copy and paste code and then make the necessary modifications such as changing variable types, modifying references to ThisDrawing & replacing On Error statements with Try blocks.
Regards - Nathan
ChrisArps
a. The dotnet api for Autocad can do much more than com.
b. You can use 2002,2003, or 2005 if you only do vb.net or C#. To use C++ and objectarx or OMF you need VS2002. I prefer the professional version to have C++.
c. If you already know VB, vb.net will be an easier transition.
d. You can convert a project, but it will add a lot of "compatability" objects that are old and typically can be replaced with a better dotnet object. I recommend translating the code manually.
e. CAO is an activex dll, so you can use it from dotnet. There should be some samples in the Autocad Program directory. I have ADT so it is at
C:\Program Files\Autodesk Architectural Desktop 2006\Sample\Database Connectivity\CAO.
Chris Arps
”Boost
