.NET
.NET
New Member
spyder3739
Message 1 of 2 (326 Views)
When plot "PNG or JPG" file, How to edit Paper Size using Custom Paper Size?
326 Views, 1 Replies
10-17-2012 05:33 AM
Hello, I have some questions.
Using ObjectARX2013, I have to solve problems.
When I plot PNG or JPG file, its paper size is needed to edit according to drawing size.
I want to know the source code or function(or method) - C#.
Please help me.
Thanks.
norman.yuan
Message 2 of 2 (298 Views)
Re: When plot "PNG or JPG" file, How to edit Paper Size using Custom P
10-17-2012 02:25 PM in reply to: spyder3739
I just posted a similar question a while ago and the reply from SENL 1363 offerred the solution I needed exactly.
Pay attention to code
plotInfo.DeviceOverride=tds;
and
validator.MediaMatchingPolicy = Autodesk.AutoCAD.PlottingServices.MatchingPolicy.MatchEnabledCustom
and
int itIs = validator.IsCustonPossible(plotInfo);
The last line of code means that you do not need to define a custom size of paper. When IsCustomPossible() called, AutoCAD will create a custom sized paper to match the defined plot area (Layout/Window...). If it returns 0, it means, you can go ahead with the plotting. For the details of the returned value from IsCustomPossible, you need to find it in ObjectARX C++ API documentation, not managed API documentation.
HTH
