.NET
h.sezenn
Message 1 of 5 (3,108 Views)
when line change?
3108 Views, 4 Replies
11-18-2013 04:13 PM
hello everybody, I have a question.
There is a line in my draw ( on picture first action ) when I change it ( on picture second action ) , after changed it, I want to know its modify last point [ like p2(2500,1000) ]. how Can I do it with .net
Also I have lots of line on my drawing, I want it, for all of my line which are changed. Is there any way to do it?
thanks everybody :smileyhappy:
_____________________________________________________________________________________
Everything For Duct
This is happening because you are adding line and that line is pointed to the event handler. So which last line is added through the code it is showing only that line's information. However, I have written few lines for your purpose. It will track database modify event. if database is modified and modified object is line only then the event will be triggered. Please see below code if it serve your purpose.
Dim objIdColl As New ObjectIdCollection()
<CommandMethod("TST")> Public Sub TESTLine()
Dim doc As Document = Application.DocumentManager.MdiActiveDocument
Dim db As Database = doc.Database
Using tx As Transaction = db.TransactionManager.StartTransaction()
Dim bt As BlockTable = tx.GetObject(db.BlockTableId, OpenMode.ForRead)
Dim ms As BlockTableRecord = tx.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForRead)
For Each id As ObjectId In ms
objIdColl.Add(id)
Next
End Using
AddHandler db.ObjectModified, AddressOf acLineMod
End Sub
Public Sub acLineMod(sender As Object, e As ObjectEventArgs)
If objIdColl.Contains(e.DBObject.Id) Then
If TypeOf e.DBObject Is Line Then
If e.DBObject.IsModified Then
Dim ln As Line = TryCast(e.DBObject, Line)
MsgBox(ln.EndPoint.ToString)
End If
End If
End If
End Sub
mzakiralam
Message 2 of 5 (3,084 Views)
Re: when line change?
11-19-2013 01:24 AM in reply to: h.sezenn
You can find a line end point with below code
<CommandMethod("TST")> Public Sub TestLine()
        Dim ed As Editor = doc.Editor
        Dim peo As PromptEntityOptions = New PromptEntityOptions(vbLf & "Select a line:")
        Dim per As PromptEntityResult = ed.GetEntity(peo)
        If per.Status <> PromptStatus.OK Then
            Return
        End If
            Dim ent As Entity = tx.GetObject(per.ObjectId, OpenMode.ForRead)
            If TypeOf ent Is Line Then
                Dim ln As Line = TryCast(ent, Line)
            End If
            tx.Commit()
        End Using
    End Sub
 But if you want to get the end point after modify it , then  you have to use object event handler. In that case , you can go through the below link which will give you a proper guideline.
http://exchange.autodesk.com/autocad/enu/online-help/browse#WS1a9193826455f5ff2566ffd511ff6f8c7ca-36...
h.sezenn
Message 3 of 5 (3,059 Views)
11-19-2013 03:32 PM in reply to: mzakiralam
Thank you your answer. at this link code that worked. but there is a problem in code.
I recode again for my self.
I draw lots of lines on my draw area. after draw some lines. I want to modfy any of them( for example first drawn line ), but After I modfy the first one line, alert massage show that's last line's end point. but I want to know first line's end point( which I modfy line)
is there any solition about that? can we do it line's id number?( Line.Id)
thanks alot :smileyhappy:
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.EditorInput
Public Class _20_11_13_soru01
    Dim Line As Line = Nothing
    <CommandMethod("CTE01")> _
    Public Sub cte_01()
        Dim Doc As Document = Application.DocumentManager.MdiActiveDocument
        Dim Db As Database = Doc.Database
        'NOKTA SEÇİMİ İÇİN GETPOİNT OLUŞTURULDU
        Dim pPtRes As PromptPointResult
        Dim pPtOpts As PromptPointOptions = New PromptPointOptions("")
        'İLK NOKTA SEÇİMİ YAPILDI
        pPtOpts.Message = vbLf & "BAŞLANGIÇ NOKTASINI SEÇ (PİCK FİRST POİNT):  "
        pPtRes = Doc.Editor.GetPoint(pPtOpts)
        Dim ptStart As Point3d = pPtRes.Value
        Do
            'İKİNCİ NOKTA OLUŞTURULDU
            pPtOpts.Message = vbLf & "NOKTA SEÇİMİ YAPIN( PİCK POİNT) : "
            pPtOpts.UseBasePoint = True
            pPtOpts.BasePoint = ptStart
            Dim ptEnd As Point3d = pPtRes.Value
            If pPtRes.Status = PromptStatus.OK Then
                Using Tr As Transaction = Db.TransactionManager.StartTransaction()
                    '' BLOK TABLOSU OKUMAK İÇİN AÇILDI
                    Dim Bt As BlockTable
                    Bt = Tr.GetObject(Db.BlockTableId, OpenMode.ForRead)
                    '' BLOK TABLO KAYDI YAZMAK İÇİN AÇILDI
                    Dim btr As BlockTableRecord
                    btr = Tr.GetObject(Bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
                    Line = New Line(ptStart, ptEnd)
                    btr.AppendEntity(Line)
                    Tr.AddNewlyCreatedDBObject(Line, True)
                    AddHandler Line.Modified, AddressOf linemod
                    Tr.Commit()
                End Using
                ptStart = ptEnd 'LİNE ÇİZMEK İÇİN İLK NOKTA DEĞERİ Bİ ÖNCEKİ LİNE IN SON NOKTASI OLARAK GÜNCELLENDİ
            Else : End If
        Loop While pPtRes.Status = PromptStatus.OK
    End Sub
    Public Sub linemod(ByVal senderObj As Object, _
                        ByVal evtArgs As EventArgs)
        Application.ShowAlertDialog("line id " & Line.Id.ToString & "modfied end point:" & Line.EndPoint.ToString)
    End Sub
End Class
Everything For Duct
mzakiralam
Message 4 of 5 (3,041 Views)
11-20-2013 02:38 AM in reply to: h.sezenn
                objIdColl.Add(id)
            Next
        End Using
    End Sub
                End If
            End If
        End If
    End Sub
h.sezenn
Message 5 of 5 (3,021 Views)
11-20-2013 03:47 PM in reply to: mzakiralam
Thank you :smileyhappy: it works.
Everything For Duct
