.NET
When do I need to open a Transaction?
2 REPLIES 2
SRSDS
463 Views, 2 Replies
I often see examples of accessing objects without opening a transaction.
This has no reference to a transaction
Dim Ent As Entity = ObjID.GetObject(OpenMode.ForRead)
but when I try to use it in a reactor it jumps to the ObjectModified event and then not back to the continuing code.
I have this in my CommandEnded event
           ElseIf e.GlobalCommandName = "EATTEDIT" Then
                'Check if DrawingNo changed
                Dim myXdata As Array = Ent.XData.AsArray
                If myXdata.GetValue(0).value = "TitleBlock" Then
 And don't understand why I need to open a transaction to see if it's a Titleblock
What's the difference between
and
Dim Ent As Entity = trans.GetObject(ObjID, OpenMode.ForRead)
Hope someone can help.
2 REPLIES 2
chiefbraincloud
in reply to: SRSDS
and
Short answer, there isn't one.  You must have an active transaction to call GetObject.  Even when you call Objid.GetObject, the Top Level Transaction still handles the object, so if there is no active transaction it will fail.
SRSDS
in reply to: chiefbraincloud
Thanks Chief,
 It looks like I'm doing it right then.
”Boost
