.NET
Active Contributor
tangferry
Message 1 of 4 (270 Views)
What's wrong with the TrayItem's event?
270 Views, 3 Replies
07-06-2005 05:55 PM
There happens nothing when I click on the trayitem.
[CommandMethod("Test")]
static public void test()
TrayItem item=acadApp.StatusBar.TrayItems[0];
item.MouseDown+=new StatusBarMouseDownEventHandler(item_MouseDown);
private static void item_MouseDown(object sender, StatusBarMouseDownEventArgs e)
System.Windows.Forms.MessageBox.Show("Tray Item Clicked");
*Albert Szilvasy
Message 2 of 4 (270 Views)
Re: What's wrong with the TrayItem's event?
07-07-2005 10:16 AM in reply to: tangferry
You can only sink the events for the tray items that you created:
public class TestStatusBarPane
[CommandMethod("PANETEST")]
public void DoIt()
Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage("Application
Statusbar \n");
StatusBar sb = Application.StatusBar;
// add a new pane
Pane newPane = new Pane();
newPane.Text = "Hello";
newPane.ToolTipText = "Hello Tip";
newPane.Visible = true;
newPane.MinimumWidth = 40;
newPane.Style = PaneStyles.Normal;
newPane.MouseDown += new
StatusBarMouseDownEventHandler(paneMouseDown);
sb.Panes.Add(newPane);
PaneCollection panes = sb.Panes;
foreach (Pane p in panes)
Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage("Pane
-- {0}\n", p.Text);
Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage("Document
Statusbar \n");
sb = Application.DocumentManager.MdiActiveDocument.StatusBar;
panes = sb.Panes;
-- {0}\n", p.Text);
static void paneMouseDown(Object o, StatusBarMouseDownEventArgs e)
Pane p = (Pane) o;
on Click-- {0} {1}\n", p.Text, e.Button);
static void trayMouseDown(Object o, StatusBarMouseDownEventArgs e)
TrayItem ti = (TrayItem) o;
Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage("Tray
on Click-- {0} {1}\n", ti.ToolTipText, e.Button);
ti.CloseBubbleWindows();
static void bubbleClosed(Object o,
TrayItemBubbleWindowClosedEventArgs e)
TrayItemBubbleWindow bubble = (TrayItemBubbleWindow) o;
Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage("Bubble
'{0}' closed on Click -- {1}\n", bubble.Title, e.CloseReason);
public class TestStatusBarTray
static TrayItem oneNewTi = null;
[CommandMethod("TRAYTEST")]
public void DoIt()
Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage("Status
Bar Tray Item test \n");
TrayItemCollection tis = sb.TrayItems;
TrayItem oneTi = null;
foreach (TrayItem ti in tis)
-- {0}\n", ti.ToolTipText);
oneTi = ti;
if (oneTi != null && oneNewTi == null)
oneNewTi = new TrayItem();
oneNewTi.Visible = true;
oneNewTi.Icon = oneTi.Icon;
oneNewTi.ToolTipText = "copy of " + oneTi.ToolTipText;
tis.Add(oneNewTi);
oneNewTi.MouseDown += new
StatusBarMouseDownEventHandler(trayMouseDown);
TrayItemBubbleWindow bubble = new TrayItemBubbleWindow();
bubble.Text = "Bubble Text";
bubble.Title = "Bubble Title";
bubble.HyperLink = "http://google.com";
bubble.HyperText = "Cool site";
oneNewTi.ShowBubbleWindow(bubble);
bubble.Closed += new
TrayItemBubbleWindowClosedEventHandler(bubbleClosed);
wrote in message news:4894583@discussion.autodesk.com...
*Danny P.
Message 3 of 4 (270 Views)
07-07-2005 07:55 PM in reply to: tangferry
Albert,
Excellent example, thanks. Having played with this for a few minutes,
I'm really intrigued by the Popup pane style. It looks as though it's
meant to attach a menu item to. Any chance you could make a simple
example showing a menu popup and a click handler on a menu item? (or
would the menu events handle the click?)
Something like a menu with "Say Hello" and an event handler of MsgBox
("Hello world")? I can run with it from there.
Thanks in advance for your help, and thanks for everything you do here
for us,
-Danny Polkinhorn
WATG
Honolulu
PS: Here's the VB port (as well as I can do it, watch for wrapping)...
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Windows
Public Class TestStatusBarPane
_
Public Sub DoIt()
Statusbar " + ControlChars.Lf)
Dim sb As StatusBar =
Autodesk.AutoCAD.ApplicationServices.Application.StatusBar
' add a new pane
Dim newPane As New Pane
newPane.Text = "Scale: 1/8'' = 1'-0''"
newPane.ToolTipText = "Default Scale"
newPane.Visible = True
newPane.Style = PaneStyles.PopUp
AddHandler newPane.MouseDown, AddressOf paneMouseDown
Dim panes As PaneCollection = sb.Panes
Dim p As Pane
For Each p In panes
-- {0}" + ControlChars.Lf, p.Text)
Next p
panes = sb.Panes
For Each p In panes
Next p
End Sub 'DoIt
Shared Sub paneMouseDown(ByVal o As Object, ByVal e As
StatusBarMouseDownEventArgs)
Dim p As Pane = CType(o, Pane)
-- {0} {1}, Style: " + ControlChars.Lf, p.Text, e.Button, p.Style.ToString)
End Sub 'paneMouseDown
Shared Sub trayMouseDown(ByVal o As Object, ByVal e As
Dim ti As TrayItem = CType(o, TrayItem)
on Click {0} {1}" + ControlChars.Lf, ti.ToolTipText, e.Button)
End Sub 'trayMouseDown
Shared Sub bubbleClosed(ByVal o As Object, ByVal e As
TrayItemBubbleWindowClosedEventArgs)
Dim bubble As TrayItemBubbleWindow = CType(o, TrayItemBubbleWindow)
'{0}' closed on Click -- {1}" + ControlChars.Lf, bubble.Title,
e.CloseReason)
End Sub 'bubbleClosed
Public Class TestStatusBarTray
Private Shared oneNewTi As TrayItem = Nothing
_
Public Sub DoIt()
Bar Tray Item test " + ControlChars.Lf)
Dim sb As StatusBar = Application.StatusBar
Dim tis As TrayItemCollection = sb.TrayItems
Dim oneTi As TrayItem = Nothing
Dim ti As TrayItem
For Each ti In tis
-- {0}" + ControlChars.Lf, ti.ToolTipText)
oneTi = ti
Next ti
If Not (oneTi Is Nothing) And oneNewTi Is Nothing Then
oneNewTi = New TrayItem
oneNewTi.Visible = True
tis.Add(oneNewTi)
AddHandler oneNewTi.MouseDown, AddressOf trayMouseDown
Dim bubble As New TrayItemBubbleWindow
AddHandler bubble.Closed, AddressOf bubbleClosed
End Sub 'DoIt
End Class 'TestStatusBarTray
End Class 'TestStatusBarPane
Valued Contributor
tim-bot
Message 4 of 4 (270 Views)
02-29-2008 09:53 AM in reply to: tangferry
hmm... i'm frustrated, i'm using this code and there's no bubble coming up... does anyone know why?
Post to the Community
New Post
Need installation help?
