.NET
what's the trick to intersectwith ?
5 REPLIES 5
mpropst
797 Views, 5 Replies
i see references to
Autodesk.AutoCAD.Geometry
in other posts but when i try to Import that, no .Geometry namespace is attached to acad
acad2009 vbexpress2008
i was going to try to use that to create point2d or point3d thinking that might be easier than array() as Double.
as far as intersect code:
i tried
Dim NewPoint(2) As Double
NewPoint = CType(oArc3.IntersectWith(oEnd3, AcExtendOption.acExtendBoth), Double())
where oArc3 is an arc and oEnd3 is a line which would intersect if they were extended
i'm trying to find the intersection point so i can extend them programaticlly just like if i were to fillet manually
i'm getting what appears to be an empty array as a return.
but i should be getting a valid pointlist
what am i doing wrong?
thanks
mark
5 REPLIES 5
mpropst
in reply to: mpropst
this seems strange to me
the returned object from intersect with is a 6 element array!?!?!
here's the results of my 'logentry' calls
Get new point intersection arc and line
newcorner Is NOT Nothing
Try to cast to double array
vartype
8197
Ubound
5
NewPoint x
NewPoint y
NewPoint z
the code producing the above report is as follows;
Try
      newcorner = oArc3.IntersectWith(oEnd3, AcExtendOption.acExtendBoth)
      If newcorner Is Nothing Then
        m_Util.Logentry("newcorner Is Nothing")
      Else
        m_Util.Logentry("newcorner Is NOT Nothing")
      m_Util.Logentry("Try to cast to double array")
      NewPoint = CType(newcorner, Double())
      If VarType(NewPoint) <> VariantType.Empty Then
        m_Util.Logentry("vartype")
        m_Util.Logentry(VarType(NewPoint).ToString)
        ' m_Util.Logentry("Ubound ", CStr(UBound(NewPoint)))
        m_Util.Logentry("Ubound ")
        m_Util.Logentry(CStr(UBound(NewPoint)))
        m_Util.Logentry("NewPoint x", CStr(NewPoint(0)))
        m_Util.Logentry("NewPoint y", CStr(NewPoint(1)))
        m_Util.Logentry("NewPoint z", CStr(NewPoint(2)))
      Else
        m_Util.Logentry("empty array returned")
    Catch ex As Exception
    End Try
i'll have to look up that 8197 again, should be array of double I'd think
chiefbraincloud
I can't say with certainty why your array appears to be empty, but the 6 element array is because you are extending both and therefore there are two intersections.
The Geometry Namespace is in acdbMgd.dll
It appears you are using the COM API and probably don't have that file referenced.
mpropst
in reply to: chiefbraincloud
ah! I see why the array has 6 elements.
still trying to figure why i'm not getting values in the elements
variable typing with strict on is interesting - having to convert all over the place
i'm assuming it a cast problem or variable type prob, but not seeing it.
would the geom.point type objects be easier in general than arrays of doubles when working with the com model?
thanks
mark
adadnet
hi mark
1. try use the .intersectwith(..., tolearance) method;
2. try use projectedintersectwith(..., tolearance) method.
the tolerance should help address empty returns due to extreme precision of calculating coords in space, the projected... method might be better suited for your stated task.
felix
michael.robertson
in reply to: adadnet
Something else to watch for with IntersectWith methods, when used with "Large" coordinate systems (like state plane systems) you may get erratic results (I get intersections where none exist). This bug is known by Autodesk, I ran into this problem using Civil3D and the solution was I had to transpose the entities I wanted to check so that they were near the origin, check for an intersection, then transpose the intersection points back to the correct place in the coordinate system.
Autodesk couldn't really define how "Large" (their term) a coordinate had to be to exhibit this behavior so I perform the transpose routine to all intersection checks.
Mike Robertson
FL. Dept. of Transportation
CADD Applications Developer
”Boost
