.NET
What's the best way to refresh the drawing after adding blocks?
8 REPLIES 8
Message 1 of 9
1625 Views, 8 Replies
I've got some C# code (VS 2003 and AutoCAD 2006) that adds some blocks to a
drawing. It works, but the blocks are initially invisible. I have to pan
or zoom (or do anything, as far as I know) for them to appear.
I'd like to try calling the Zoom command with a scale of 1x. How do I
accomplish this from .NET?
Thanks so much for any help.
-Carlos
8 REPLIES 8
Message 2 of 9
Have you tried calling TransactionManager.FlushGraphics ?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
"Carlos" wrote in message news:4936528@discussion.autodesk.com...
-Carlos
Message 3 of 9
That sounds like what I want, but for some reason FlushGraphics is not
listed as a method of TransactionManager. I see QueueForGraphicsFlush, but
not FlushGraphics. How is that method used?
Here's my code:
Database db=Application.DocumentManager.MdiActiveDocument.Database;
Autodesk.AutoCAD.DatabaseServices.TransactionManager TM =
db.TransactionManager;
Transaction trans = TM.StartTransaction();
try
trans.Commit();
catch
finally
trans.Dispose();
TM.FlushGraphics(); ???
Autodesk.AutoCAD.DatabaseServices.TransactionManager.FlushGraphics?
"Tony Tanzillo" wrote in message
news:4936774@discussion.autodesk.com...
-Carlos
Message 4 of 9
There are two of them:
Autodesk.AutoCAD.ApplicationServices.TransactionManager
"Carlos" wrote in message news:4936807@discussion.autodesk.com...
Here's my code:
try
trans.Commit();
catch
finally
trans.Dispose();
-Carlos
Message 5 of 9
Thanks very much for your help so far, but FlushGraphics doesn't seem to be
doing the trick. Am I calling it incorrectly? My code is attached in a
text file.
I've noticed that the PAN command seems to be the only thing that will make
things work (as opposed to what I thought earlier). If I insert the blocks
from C# and then type Redrawall, Regenall, or Zoom 1x, the last block that
was inserted remains invisible until I pan. If I move my mouse over the
block, a dotted outline appears, but the block does not remain visible until
I pan.
Any other ideas?
Thanks again.
-Carlos
news:4936836@discussion.autodesk.com...
Here's my code:
try
trans.Commit();
catch
finally
trans.Dispose();
-Carlos
Message 6 of 9
Since you're doing this in a modal command handler,
there should be no problem like this.
You're not showing the whole picture, so can you
confirm that the code that creates the new entities
calsl AddNewlyCreatedDBObject() ?
"Carlos" wrote in message news:4936876@discussion.autodesk.com...
text file.
block, a do
I pan.
Any other ideas?
Thanks again.
-Carlos
"Carlos" <
carlos at sensametrics dot com> wrote in message
Here's my code:
try
trans.Commit();
catch
finally
trans.Dispose();
http://www.cadd
zone.com
accomplish thi
s from .NET?
-Carlos
Message 7 of 9
I'm fairly sure the call to AddNewlyCreatedDBObject is working, but I've
attached the code for actually inserting the blocks into AutoCAD just in
case.
I've tried all sorts of stuff. Can you see the problem?
Carlos
news:4936905@discussion.autodesk.com...
text file.
block, a do
I pan.
Any other ideas?
Thanks again.
-Carlos
"Carlos" <
Here's my code:
try
trans.Commit();
catch
finally
trans.Dispose();
http://www.cadd
zone.com
accomplish thi
s from .NET?
-Carlos
Message 8 of 9
As a side note,
I've never had to use the call to db.ReadDwgFile() because the condition
(bt.Has("Sensing Unit")) has always been met. I've had some issues with
that call anyway, so that is why it's commented out.
-Carlos
text file.
block, a do
I pan.
Any other ideas?
Thanks again.
-Carlos
"Carlos" <
Here's my code:
try
trans.Commit();
catch
finally
trans.Dispose();
http://www.cadd
zone.com
accomplish thi
s from .NET?
-Carlos
Message 9 of 9
Did you already try to use this:
Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.UpdateScreen();
Pedro Henrique Liberato, sorry the 'little' delay and the poor English 🙂
”Boost
