I am trying to scale down a table by half and "scale factor doesn't work. Am I doing something wrong ? it always come in original size and not scale - I tried to put the line before transaction and after appent and before , Here is Code.
Need help ,Thanks.
Janet.
Using tr As Transaction = Mydb.TransactionManager.StartTransaction Dim btr As BlockTableRecord = tr.GetObject(Mydb.CurrentSpaceId, OpenMode.ForWrite) btr.AppendEntity(tb) tr.AddNewlyCreatedDBObject(tb, True) tb.ScaleFactors = New Scale3d(0.5) tr.Commit() End Using
Solved by Alfred.NESWADBA. Go to Solution.
Try this
tb.TransformBy(Matrix3d.Scaling(0.5, tb.Position))
tr.Commit()
Or perhaps
tb.ScaleFactors = New Scale3d(0.5,0.5,1.0)
Thanks Hallex,
Option one is not what I want . Because the scaling is in a point monitor event, and everytime user moves the mouse it scale down another time.
option 2 doesn't work either.
Appreciated your help though.
Janet.
Then you check current size to decide if the table has to be scaled down or up or not, just one "if" ... 😉
....or there is something missing in your description to get that understandable for us.
- alfred -
@Janet,
In this case you may want to use DrawJig
because of inside the event just SendStringExecute
is working properly and interactive command should be ignored
