.NET
what is the best use for a Windows Form ?
3 REPLIES 3
AubelecBE
516 Views, 3 Replies
HI all.
What is the best way for launch a Form  ?
if Autodesk.AutoCAD.ApplicationServices.Application.ShowModalDialog(Fenetre) = Windows.Forms.DialogResult.OK Then
end if
or
if Fenetre.ShowModal = Windows.Forms.DialogResult.OK Then
end if
I dunno what it the best way for it ?
How i can launch a child of MDI Form ?
in the Init of a MDI Form :
        FenetreCouleur = New FormConf0a_Couleur(Def)
        FenetreCouleur.MdiParent = Me
        FenetreCouleur.Show()
i use .show  it is the best way  ?
3 REPLIES 3
StephenPreston
in reply to: AubelecBE
Use Autodesk.AutoCAD.ApplicationServices.Application.S​howModalDialog to display a modal dialog. This API was introduced to overcome some problems associated with direct calls to Form.ShowModal from a. AutoCAD plug-in.
Cheers,
Stephen Preston
Autodesk Developer Network
AubelecBE
in reply to: StephenPreston
ah ok thx.
and for the mdi child ?
Hi
Are you referring to modeless dialog? If yes, then use Autodesk.AutoCAD.ApplicationServices.Application.ShowModelessDialog
You can also refer http://adndevblog.typepad.com/autocad/2012/06/displaying-modal-and-modeless-forms-in-autocad-net.htm...
Virupaksha Aithal KM
Developer Technical Services
”Boost
