Hi guys !
Im really new to vb.class (Autocad)
As per the attached printscreen...
Is it better to have one file for each vb.class(like printscreen) or it's better to put it all in one vb.class ?
Maybe noob question, but I want to know...
Thanks in advance !
Solved by bjhuffine. Go to Solution.
When working with objects there are many things you have to consider. I'm a fan of the domain driven design (DDD) philosophies. Since you're just beginning, here's a couple of things I would start off with. There's plenty of material out there on this and many, many books, so I would encourage you to research these. Hopefully these concepts can be starting point as you study and build your personal knowledge base. Bullet #2 more directly answers your question.
4. As you learn more on how to create and design your system, I would research design patterns as well. Their intentions may not be obvious to you at first but if you get used to them they can really save the day by allowing you to create a more flexible, maintainable, and extensible system.
In the same subject...
Is it a good idea to put all functions that I used in many others classes, in a one specific file ?
Or, it's preferable to copy the function in each classes ?
Thanks again !
Code reuse is a really big deal. If you have methods that manage the same process repeated in several places, then any change has to be repeated with each method. And that's if you remember where each one is located. Chances are great that you'll miss one. Definitely keep functionality in one operation. Again, a lot of this depends on how you design your objects. If, for example, you create a factory class that creates a complex object, then you have all of that object creation code in the one class (Single Responsibility Principle). Any time you need to create the complex object, create an instance of your factory class and call it's Create()... or whatever... method. No need having to repeat the creation code. Object Oriented Design (OOD) means treating each class/struct like its an object that's capable of interacting with other objects. If the function would have to be repeated with similar objects, then inheritance can be used to ensure that the function is still in one place in the base class. For example say you have three classes Employee, Manager, and Intern. You don't want to repeat a property that queries and returns their mailstop in each one. But since each carry the same principle properties and methods, they could all three inherit from a Person class which would have the MailStop property and the other three would automatically inherit it. Most of the time you can isolate your code for reuse. Anything short of those rare exceptions I believe can create a mess down the road.
Another principle to consider is Inversion of Control. IoC is a term that's been around for ages and depending on the type of development work you do can mean something slightly different. But the point I want to get across is the idea that you don't build a class that manages the processes in one step. That alone breaks SRP as well as Open/Closed principle, etc. With IoC you design objects that encapsulate the functionality it's designed to manage. Either at the application level or with a Service class you can manage the process by instantiating objects and calling the appropriate methods at the appropriate times. Effectively inverting control from the top down to the bottom up. Since you're just beginning, don't worry about all that. Just remember that an object decribes an object: Properties are attributes of the object and Methods are the actions an object can take. From there learn how to create instances between classes and call the operations you need.
