.NET
what happen to the file of AcMgd.dll in my project
10 REPLIES 10
Message 1 of 11
jiallxy
1436 Views, 10 Replies
 Hi ,
Is there somebody can help me?
Everytime, I build my project, there is following warning coming out and asks me to remove the reference file "ACMgd".
Warning 1
 The referenced assembly "AcMgd" could not be resolved because it has a dependency on "System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" which is not in the currently targeted framework ".NETFramework,Version=v4.0,Profile=Client". Please remove references to assemblies not in the targeted framework or consider retargeting your project. AutoCADHoodDWG
Best regards,
Jusitn
10 REPLIES 10
Message 2 of 11
glanard
in reply to: jiallxy
- Do you use the correct release of ObjectArx?
- In VS, did you switch its "Local Copy" property to FALSE?
Message 3 of 11
I suppose that you are working with Autocad 2013, if I'm correct, review yor project properties, the target .NET Framework for your app mus be 4.0 (probably you have 3.5).
Luis Alberto Manero, Geograma.com
Message 4 of 11
jiallxy
in reply to: glanard
Hi
I use autocad2012 64bit version with win7 64bit os. The C:\ObjectARX 2012 is my folder for ObjectARX.
I use VS 2010 C# to program a stand alone application.
all of them are reommended by autodesk's website. They shuould work together properly.
Message 5 of 11
jeff
@jiallxy wrote:
 Hi ,
Warning 1
Best regards,
Jusitn
Try retargeting to full .NET 4.0 version instead of Client.
You can also find your answers @ TheSwamp
Message 6 of 11
norman.yuan
Now than you mentioned this:
<quote>
</quote>
Please be aware, the Acad .NET API assemblies (acdbmgd.dll/acmgd.dll...) can only be used inside AutoCAD (if you do Acad addin DLL project). You CANNOT use them with stand-alone EXE project.
Norman Yuan
Drive CAD With Code
Message 7 of 11
Alexander.Rivilis
@jiallxy wrote:
Hi
Do I understand correctly that you're trying to make external exe-file (not dll-file that will be loaded with NETLOAD command into AutoCAD)? If so, then you can not use acmgd.dll and acdbmgd.dll in your project.
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 8 of 11
jiallxy
in reply to: Alexander.Rivilis
Yes, you are right.
I have just found that these two dll files only can be used in add-in projects.
I have to use COM interop: Autodesk.AutoCAD.Interop
The problem is that the COM interop have less good functions and is more difficult to program.
I will try to balance which way I should choose.
thank you very much!
Message 9 of 11
jiallxy
in reply to: norman.yuan
Yes, you are right.
I have to use COM interop: Autodesk.AutoCAD.Interop for standalone application.
Message 10 of 11
jiallxy
in reply to: jeff
Thank you!
I changed the framework type, and it works!
Message 11 of 11
ELMODE
I HAVE APROPLEM WHEN RUN AUTOCAD 14   in wen 8
 ITS SHOW ME MASG ON IT
(( FATAL ERROR: UNHANDLED ACCESS VIOLATION READING 0x0020 EXCEPTION AT 2bfe1dc7h))
help me --- iam need thes program
”Boost
